Except they are hideously ugly![]()
Touche, but not when next to a Hyundai coupe
Touche, but not when next to a Hyundai coupe![]()
Astra coupe could be another alternative in the same mould - again they're alright really, just an ashtray so easy to sort have decent seats too
2.0 Turbo Coupe is pretty good as well, not a great lover of the chassis mind, always found the steering a little vague, mind you then so is my CLK's.
Talking of which a CLK 230-320 is on budget![]()
Unless you're very clued in mechanically then I would say that's the correct stance to take.
Merc parts tend to be an absolute fortune too
That's my take you are correct.
Back in the early 90's I was a mechanic for a family business but things have changed and I haven't. I work as a teacher now, not mechanical.
I am probably really out of touch but a 2.7 V6 producing a peak 165 BHP from my schooling is likely to be far more reliable than a 1.8-2.0 producing 165bhp+ peak.
The Torque levels seem to be ignored, driving a diesel with 150+bhp sounds great but you tend to find the power comes all at once between a rev range of 3000-4000 RPM.
I am not looking to race the car, but would ideally like to have a nice pull and smoothness or a V6/6 cylinder rather the screaming 4 cylinders.
The Coupe body is a personal choice as I am sick of me being able to take passenger comfortably. Plus I would like a coupe as I have regretted getting rid of my Alfa GTV6 since the day I did it.
It doesn't necessarily work like that in any case, but in this specific case the 2.7 is a dreadful engine.
You really would not gain anything from buying this car over a 2.0 car.
On top of this the hyundai coupe is a dreary uninspiring drive with any engine in it.
You want one, they're not terrible, you've done your homework on them, get one!
Yeah I was looking at CLK's but I am concerned what sort of example I am likely to get with a 2-3k budget.
£2k not so good, £3k will get a great example, mine was at the bottom end, but is rapidly approaching the better end.
You should be looking at low mileage facelift models for £3k, 320 engines are nigh on bullet proof, as is the auto box, but watch out for the radiators, valeo ones can lunch the transmission by mixing coolant with transmission fluid on the 2000-2001 models, thankfully many have now been swapped for Behr models.
http://www.ebay.co.uk/itm/Mercedes-...6097897?pt=Automobiles_UK&hash=item2eb8091269
That is the kind of one I would be looking at, but have a good check for rust. Many you see in good nick nowadays have been treated and resprayed with a better quality paint. Mine has had a respray but wasn't a great job, so I will be getting a couple of panels redone and the rest of the car paint corrected.
I am not an old git but I am 38 and very soon 39.
well 47 anyway, and it is so relaxing to drive with the best cruise control system I have ever used. The elegance is a bit wafty for some, if you want some thing a bit sportier, get the Avantgarde.I amwell 47 anyway, and it is so relaxing to drive with the best cruise control system I have ever used. The elegance is a bit wafty for some, if you want some thing a bit sportier, get the Avantgarde.
Thank you I am now searching Autotrader. Not being funny but can you see where I am coming from, me in a -2.0l turbo revving at the lights. Not good lol. But I have 20+years driving experience and would like something that looks to the untrained eye as well as goes well when you want it.
