**QUITE POSSIBLY SOME OF THE BEST LOOKING MEMORY YET!!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Staying on the subject of memory, OcUK has an exclusive on Patriot's Intel Extreme Masters Limited Edition memory, check them out here:-
Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K)
The Intel® Extreme Masters (IEM) Memory, a limited edition kit designed with true performance and gamers in mind. These modules are hand tested and compatible with the latest Intel® DDR3 platforms to ensure stability for the most intense gaming environments. The Intel® XMP Certification ensures a seamless gaming upgrade and experience.
The Intel® Extreme Masters, Limited Edition utilizes the Viper 3 variation design for its heat dissipating capabilities for superior performance to ensure rock solid stability even when using the most taxing applications. Built with the highest quality of components, we back our memory with a lifetime warranty.
Available in dual and quad channel kits, 8GB, 16GB and 32GB Kits, Patriot Memory’s IEM Edition will be offered at speeds from 1600MHz up to 2133MHz at 1.5 volts. This exclusive memory by Patriot Memory will only be available during Season 7 show of IEM. Visit www.intelextrememasters.com for more information.
Features:-
- Extreme Performance PC3-12800 (1600MHz)
- Low Latency (9-9-9-24)
- Voltage: 1.50-1.60V
- XMP Ready
- Equipped with an extruded aluminum shield build around a copper core to provide improved cooling
- 100% Tested and Verified
- RoHS Compliant
- Tested on Intel 6 & 7 series platform
- Lifetime Warranty
Price: 49.99 Inc. VAT!!
BUY NOW!!
We shall be expanding the range of Patriot Intel Extreme Masters memory to include some of the other capacities and speeds in the coming weeks. :)
Yeah it's down to taste, if i had the RAM id love it, but as far as looks go it doesnt do anything special for me.
I'm getting an i7-2700K very soon, what is this XMP i here about? I've seen it on some HyperX Blu Kingston RAM but i forgot to look into it.
