Mac Games ?
Caporegime
8 Sep 2006
On Ocuk
Wasn't sure where to put this, especially as i'm not a lover of macs but my little sister is now using the imac ( core duo/1gb/leopard ) system after i completely wiped and re-installed.
She's playing Minecraft but what other games would be good for her?, any free ones?
Not having much luck so far :(
Ignore: Didn't see she was running Leopard :/
Minecraft should be more than enough though!
Could you not dual-boot and run games which need windows also?
Also possibly the wrong section!
the only other game that i know works on a mac is portal, not sure about which mac OS it needs though because i've never bothered with them
other than that have a look at the technic pack and MultiMC, both of which i believe work for macs. the technic pack is a ready made modpack for minecraft and multiMC makes creating your own modpack super easy in minecraft. i believe the FtB team are making their own modpack which will probably be better than technic and i know that direwolf has made a tutorial for installing all the mods he uses for his letsplay, which is like the technic pack but better
Diablo III, World of Warcraft (not saying they would be good for her :P), anything by Valve or iD.
Or you could just dual boot Windows on it giving her a much better choice of games.
