Posting on behalf of someone else just to get some insight/opinion on this problem.
Ford S-Max 2007 Model, Turbo Diesel with ~24,000 miles. Bought privately but in warranty. Shortly after buying it intermittent CEL lights and power issues, was diagnosed as a turbo issue and repaired under warranty at the Ford Dealership.
Some months later, the same thing occurs again, some £100s are spent rectifying the problem. Now the problem has resurfaced with less than 1,000 miles on the repair. Car goes back to dealership and they refuse to fix the problem that was supposedly already resolved, both in warranty and out.
In discussion with Ford UK they say that the car must be run at between 50-60 mph for at least 15 minutes, words to this effect are apparently printed in the vehicle manual. We live in Jersey, the speed limit is 40MPH. Doing such speeds would be breaking the law, nevermind for an extended period of time like 15 minutes.
Ford refuse to make good but this also opens up a whole host of questions.
- Why are Ford selling vehicles not fit for purpose in Jersey (Channel Islands as whole) IE - Selling diesel powered cars that, as a requirement, must be run at over 50MPH in a region where 40MPH is the fastest you can go
- Why does NOBODY at Ford make mention to this requirement and make clear to the buyer than not following this requirement will land you with a dead turbo that Ford will not warrant
- Why did Ford replace/repair the Turbo under warranty knowing about this problem but said nothing? Repairing it knowing that it would occur again?
Ford seem quite happy to sell diesel powered cars which have this inherent fault that, supposedly, Ford do know about
Suffice to say this will be taken to local media and it appears that it's not just Ford. Other brands have had similar issues with Turbo diesels, some of which have an entirely different turbo diesel setup now to fix the issue. Why was no recall issue or at least communication made to Channel islands owners when this fault was discovered?
Looking for opinions or insight anyone in the trade (Or not) might have as this is clearly a massive problem.
Edit - Excuse the 'diesels' spelling fail in topic subject!
