Actually, low back pain is an indication of poor movement/poor posture/muscle weakness or imbalance/more serious problems.
I would put money on "too much weight" not being a problem.
Of course it can, but it's far from the most likely cause.too much weight can lead to poor movement/poor posture/muscle weakness or imbalance/more serious problems
Squat (Smith machine) = 125 kg
not having a clue what they are doing, not being flexible enough, having imbalances are more likely to lead to poor movement/poor posture/muscle weakness or imbalance/more serious problems than too much weight tbh.
Just got back from my first gym session in a while. I've tried so hard to get my form correct, but I'm still convinced it's pants and is damaging my joints and back
For example, I've watched so many videos and followed Morba's advice on bent over rows. But it's doing sod all to workout my back and instead kills my triceps. I'm not convinced by the other exercises I've done either.
What are my options from here? I'm so desperate to get my form right so I can workout properly. Next time I workout, I'll record my lifts and upload the vids here. Would it also be worth significantly lowering the weight I'm lifting? This would probably allow me to get my form better, but it wouldn't stress my muscles at all would it? And if the weights are low and my form is still wrong, I wouldn't realise because it wouldn't really affect my joints/back.
Damn, working out is just so depressing.
What you're describing is just poor movement, which will be happening regardless of weight. It might be more obvious the layman when the weight is heavy, but it will still be present at lighter weights. Flexibility can't get worse because the weight is heavier either.TBH too much weight leads to all those things.
If you try to squat to heavy and you are not conditioned enough to handle it your form, posture, movement, balance and flexibility through the hips will go to pot through the movement. This leads to over compensation to try and get the bar back up to standing position,which leads to rounding out of the back and a 1 way ticket to a shot lower back.
Most new lifters problems start with too much weight because many of us are too stupid to leave our ego's at the door.
Maybe try seated cable rows, lat pulls, pull ups, one arm dumbell rows for a few weeks to build back strength before moving on to barbell rows ? Its rally important to get form right with any kind of bent over rowing action or squats as incorrect form could lead to an injury which would set you back months if your recovery is slow.
Post videos!
How weight are you actually using, TC?
Don't use less weight.
Triceps hurting in a dumbell row? Interesting.
The only thing I can think of without being in a gym is that you're going funny at your elbow at the top of the row by trying to keep the dumbell in a certain position.
Post videos ftw.
sounds like arm might be moving in more of a tri kickback action than a row if getting Tricep action in a row ???
