The 1.3 of that age car was the dire ohc engine.
They are dire, but if its OHC then something is well and truely wrong!!!
I bet if it broke down or died she'd be telling all her mates that KAs are crap. I'll never understand why people don't service cars properly.
For a £500 car, you do not want or need £200 servicing costs each year. Bangernomics dictates check all levels, tyres, lights. Keep on top of rust. Pre MOT test check up will tell you of any major problems if you are not mechanically minded. Most jobs are relatively simple with a good manual and a few tools.
+1Just an oil service each year would have been next to nothing.
A gallon of oil, oil filter, air filter and cabin filter does not cost £200. If you're running about in a £500 car I doubt you can afford a new engine so for the sake of a cheap service it makes sense to actually maintain something properly.
IAlthough, my other half still thinks you don't need to service a car, and told me I've wasted £45![]()
The heater control valve is electrically operated and it's very common for them to stick in one position.
