**DELL U2713HM ARRIVES AT OcUK!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
I know a few have been waiting for this new monitor from DELL to make an appearance and well our stock has now arrived:-
Dell UltraSharp U2713HM 27" Widescreen LED Monitor - Midnight Grey @ £575.99 inc VAT
Cinema-like clarity shines on the expansive 27" DellTM UltraSharp U2713HM monitor. Comfort settings and connectivity options help keep you productive. WQHD resolution and accurate colors out of the box: Superb clarity with 2560 x 1440 resolution and over 3.6 million pixels. Features a color gamut of more than 99-percent sRGB.
Excellent comfort and usability: Full adjustability including swivel, tilt, height adjustability and pivot which lets you easily switch to portrait mode. Eco-friendly design: Compliant with the latest environmental standards and made using environmentally conscious materials
2560x1440 WQHD resolution: Over 3.6 million pixels provide amazing clarity on a spacious 27" LED-backlit display. Easily adjust screen brightness to suit your environment. Accurate color right out of the box: Carefully color calibrated at the factory, the U2713HM monitor features more than 99-percent sRGB color space for impressive color from the moment you set it up. Wide-angle viewing: Uncompromised color consistency across an ultra-wide viewing angle of 178°/178° gives you broad viewing flexibility and lets you collaborate easily.
Full adjustability: Work comfortably and view images from a variety of positions with swivel and tilt. Easily switch to portrait mode with pivot. Set your U2713HM to the optimum height with a height-adjustability range of 115mm. Latest connectivity options: Seamlessly connect your monitor to your desktop, laptop and peripherals such as digital cameras and Blu-ray or DVD players. Digital and analog connections include four USB 3.0 ports, DisplayPort 1.2, DVI (HDCP) and HDMI. Stay productive with Dell Display Manager: This one-stop software tool lets you quickly access applications such as Auto Mode, Easy Arrange and PowerNap. Use Auto Mode to adjust or auto-assign preset modes to specific applications. Use Easy Arrange to neatly tile your applications, arranging them in your preferred layout
Meets latest environmental standards: The U2713HM monitor meets EPEAT® Gold and TCO Certified Displays standards, is ENERGY STAR® qualified and CECP compliant. Made with responsible materials: This monitor is made with arsenic-free glass, a mercury-free panel, uses 25-percent post-consumer recycled plastics in its chassis and BFR/PVC-free laminates in its circuit boards. The U2713HM also ships with environmentally responsible packaging. Helps save resources: Enable PowerNap mode to reduce power consumption by dimming the monitor to minimum brightness or by putting it into sleep mode.
Features:-
- LED Backlit
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 2,000,000:1
- Brightness: 350cd/m²
- Response Time: 8ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Analogue, 1x DVI-D, 1x HDMI, 1x DisplayPort,
- 5-Port USB3.0 Hub
- VESA Compliant
- Dimensions: 639.3mm (25.17'') x 200.3mm (7.89'') x 424.3mm ~ 538.9mm (21.22'' ~ 16.70'')
- Weight: 10.20kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
Was [£599.99] Inc. VAT
Only £575.99 inc VAT.
ORDER NOW
Another truly amazing panel from DELL, superb image quality without a doubt and a USB3.0 Hub. :)
Right, i know the ul is one of the best monitors arround at the moment. but for this price i would like it to look a bit more impressive like the Samsung S27B750VS for instince.
This looks like its from a BT call centre. If its just me that thinks this then ill go sit in the corner and mutter quietly to myself
I know what you're saying, but if you click the link and look at some of the other pics. It doesn't look bad at all. Not my favourite but not bad.
Now... 3013? :D
yeah the TFT central review seems to be pretty good, the wide colour gamut is probably the only thing that might niggle some people. For me personally the other thing I would have preferred is it being 1600p - I'm so used to the 16:10 with my LP2475W that I do notice the missing pixels on 16:9 monitors.
As for the looks I kind of like them simple and understated - lets face it we shouldn't be looking at the monitor but what's on it! And I definately prefer its stand to a lot of the cheap looking stands you get on other monitors, plus from the side and back its actually quite an attractive monitor.
