PSU Cables - Can't Seem to Work Mine
20 Jan 2012
Dublin, Ireland
I believe Your on about the CPU power slot.
Does it look like this ?
if So, If you have a 6 or 8 slot connector I believe they are okay to plug into it.
EDIT: get confirmation on that before you possibly short your system.
Yes, it is the 4pin 12V opening. I have no idea what to do, as no cable came with my PSU that would fit into it.
