Caporegime
- 11 Mar 2005
- Leafy Cheshire
Split my plastic DV, it's a well known problem.
Belts, waterpumps, abs sensors and MAF's really.
A very different car to the Accord - given the choice that's what I'd pick but I do have a soft spot for both the Leon and original octi VRS
). If you look carefully, you'll be able to get a lot for your money, as mine had: Electronic leather seats/mirros, Climatronic etc..Split my plastic DV, it's a well known problem.
Amen to that! My one was on at various points - intermittent miss fire (first signs of a coil pack on the way out), coolant sensor (twice), Lamda sensor, Secondary air pump, Oil level sensor etc.
Mechanically though the engine was fine up until 110k. Only times it ever went belly up from a driving perspective was twice with a duff coil pack (carried a spare so 5 minutes and I was on my way) and once when a pipe came off my newly fitted Forge recirc valve but that was my fault
Unfortunately my one went from never using a drop of oil between services to downing a litre every 600 miles and the rear end was constantly plastered in black sooty smudges. We are hoping to move house soon and were planning to drop to one car to help pull together a bigger deposit so I just gave it away at auction in the end.
With regards to the Octavia vRS specifically... while the engine itself was generally ok (apart from when the oil sensor shorted out taking out a fuse, melting a chunk of wiring loom and left the car running like poop) the rest of the car wasn't afraid of falling apart at various points. Multiple springs, track rod ends, drop links, steering racks etc. soon got annoyingly costly. It also rattled like an old van at the back end, was quite embarrassing to give people lifts in it. That said, maybe I was expecting too much coming from my 306 which needed nothing more than a rear brake cylinder between 63k and 117k miles.
they only have a lightweight rubber/plastic diaphragm, there is no way they will last forever. 10 years is doing well.
i do have a dead forge too, im really not a fan of that design, i stick to OE vag items. the N revisions seems to last well
I forgot about your old 306. For me it's been mostly the opposite experience - my 306 broke all the time whereas mechanically (other than this frickin' EML!) my vRS has been fine for the 5 odd years I've had it.
They have their niggles! I had a Golf 1.8 20vt for a couple of years which was ok bar niggles, not really engine related though.
This is a buying guide/checklist I made, give you plenty of ideas on what goes wrong on golfs, leons, similar vags really. They all have the same traits! Word 2003 doc: Clicketh Here
