Hey Guys Ive orderd my parts & am getting ready to build my first PC but Im still trying to figure out how to get the best airflow with what I have, from what Ive read I belive that the face side of the fan is the Pull side (& the back of the fan with the braces & wires is the Push side) please correct me if im wrong. Below is a quick Pic I made to show my current plan for the parts Ive orderd.
(the 2 fans going on the top are >
http://www.overclockers.co.uk/showproduct.php?prodid=FG-004-CS )
mounted through the case like so >
A friend reccomended that I use the 2 fans on top & also have the stock fans from the H100 mounted to the other side of the radiator (inside the case) for a total of 4 fans on the H100 but im not sure wether thats a good idea or not. (and what direction they should all be if i should do it.) I also cant decide if i should have the fans around the H100 (wether its 2 or 4) facing up (to take air into the PC through the case/radiator or to have the fans turned upside down to have them pulling air out of the case through the radiator. (Any adive would be greatly appreciated).
I also have a silly question about static, saying to just touch a piece of metal and others saying to have the PSU on & touch it. Id just like to clear up what the best course of action would be
Thanks4yourtime
Thanks4yourtime
