When you get to the checkout, before you enter your CC details, switch off the proxy for security reasons***, it still goes through in rupees, you'll see that before you press the buy(or whatever) button.
I read it correctly. You're trying to cover your arse by saying switch off the proxy but advising people to jump on this trick is just a bad idea.
Sleeping Dogs £21 steam key.
Greenman Gaming with this code:
GMG30-AUGUS-TWINS
Any further info ont his code? 10/2030% off?
Damn, I can't buy Dawnguard on ShopTo. Says I can't get a digital product 'coz I've never ordered a physical one before from them. When did they change that then as I've otdered a download from them before.
You really aren't doing yourself any favours by passing financial details through random proxy servers just to save 20 quid.
Found a GW2 for £32 https://www.coolshop.co.uk/catalog/product/53405-guild_wars_2_pc#
Does anyone know if this has the 1 day headstart included?
If so, when would I be emailed the code?
Also, are there any good Guild Wars 2 Standard + 1 day headstart offers/vouchers available? Thanks.
.Gray Matter (which I have been after cheapish for a while), is £5.75 on gamersgate at the moment. I will be investing.
Also, Shopto is having a bank holiday sale, a fair few PC games on there for anyone interested: http://www.shopto.net/product/search?platform=&menu=sale
Thanks for the heads up, is there an easy way to identify which 'PC downloads' are Steam codes?
. (EDIT: Saying that actually, if you're going to buy it over the next few days, you may aswell go for it on GMG and use the discount code, works out another 64p cheaper I think
)The proxy you are picking isn't working then, bought a friend BF3 through proxy on Friday and it took a lot of goes with different proxies before it worked- took about 20 mins to find one, patience does get you it for £8.50 though.
***Looking back, I didn't put it on the post but I did say to check previous posts from the link I provided.
