what is the right measurements ?
27 Jan 2005
Letchworth Herts uk
Hi All I need some help regarding the Dimentions of the LG 42LM620T i,ve searched the net and a lot of websites says the T.V is 93.3 wide with the stand but one place says its 99.3 with the stand can any one help ? :confused:
Found this:
Without stand 933 x 594 x 35.5 mm, with stand 933 x 660 x 263 mm
Doesn't make sense though!!
Straight from LG:
SET (w/o stand) (mm)
Including stand (mm)
VESA Dimensions (mm)
933 x 594 x 35.5
933 x 660 x 263
400 x 400
I think they may have with and without stand mixed up as it gets thinner with stand :P
Found this:
Straight from LG:
933 x 594 x 35.5
933 x 660 x 263
400 x 400
Hi there yeah thats what i was thinking ! but is the width right ? i noticed the Sony 40 inch T.V is 95mm wide but the LG 42inch is 93.3 wide doesn,t seem right to me ?
Possibly due to the razor thin bezels?
Is it going into such a tight space that it matters? Maybe knock down an inch or 2?
Found this:
Straight from LG:
933 x 594 x 35.5
933 x 660 x 263
400 x 400
the way i see this it means that the stand increses the overall height by 66 mm and the depth of the stand increses the plan/footprint of the tv to 263 mm but the depth of the actual tv is 35.5
so i recken the infomation is correct but a bit confusing without a picture :)
yeah i think you right :) so is the bezel why the Sony is wider than the 42 inch LG even though its 40 inch ( Sony ) ?
probably'try comparing the two tvs pics side by side.
my lg 50" tv is nearl as wide as a 60" due to the side bezals/speaker's
