**AMD HD 7800 SERIES NOW COME WITH FREE SLEEPING DOGS, NEXUIZ & DIRT SHOWDOWN PC GAMES!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK are going one better than all our competitors, not only do we have great pricing on all the premium brands of 7800 series, we are now also providing with every purchase of a 7800 series card FREE Sleeping Dogs, Nexuiz and Dirt Showdown PC Games. Thats over £50 worth of games, that makes the 7850 almost £100 :eek:
The Sleeping Dogs codes shall be emailed to the address you placed your order with 7th September onwards, so ensure your providing a valid email address when you place your order. The other games shall come as vouchers with your order.
Here is some of our best 7800 series deals:-
HIS HD 7850 IceQ X 2048MB GDDR5 PCI-Express Graphics Card (H785QN2G2M) w/ Nexuiz, Sleeping Dogs & Dirt Showdown PC Games @ £161.99 inc VAT
Thanks to the 9.2cm silent fan, massive amount of cool air is drawn from the central fan to cool down the GPU and graphics card directly. 2 heatpipes optimize cooling performance by removing heat from the core area, providing ultimate solution for professional gamers and HTCP users.
IceQ X is one of the quietest coolers. The card is below 28dB when watching movies, surfing Facebook, working. The card is quiet in 2D mode and remains quiet whether you are gaming, online socializing, entertaining or working.
The new architecture of the card gets more usable processing power for your money, enabling better frame rates in the latest games at high resolutions. In addition, with AMD PowerPlay™ & AMD PowerTune technologies, you can optimize the balance between performance and power consumption of your system by adjusting the engine clock during runtime of the card. Manage the power and keep your wallet loaded!
Features:-
- Core Clock: 860MHz
- Memory: 2048MB GDDR5
- Memory Clock: 4800MHz (Effective)
- Processing Cores: 1024
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Warranty: 2 Years
- Supplied with Nexuiz & Dirt Showdown PC Games
- All Orders placed on the 30th August 2012 and after shall recieve a FREE copy of Sleeping Dogs PC Game worth £29.99 completely FREE (Subject to availability) - You will recieve your gamecode from 7th September onwards in the email address you provided when placing your order!
Only £161.99 inc VAT.
ORDER NOW
HIS HD 7850 IceQ 2048MB GDDR5 PCI-Express Graphics Card (H785Q2G2M) **OcUK Exclusive** w/ Nexuiz, Sleeping Dogs & Dirt Showdown PC Games @ £185.99 inc VAT
This HIS 7850 IceQ is a very special card and one which is exclusive to OcUK. Built using a 7870 PCB and the IceQ cooler from the 7870 this card has truly immense OC potential. Not only that but in its quiet mode the card operates in near silence. There is no better 7850 on the market and exclusively available from Overclockers UK.
With IceQ, the card is up to 20 °C cooler than the Reference Cooler. The super large 80 x 21.5mm single blower fan draws massive amount of cool air to cool the GPU directly. The fan is equipped with 2 ball bearing and is extremely durable with a life span of 50,000 hours! 4 wide heatpipes optimize cooling performance by removing heat from the core area. The extra large 35 x 30mm copper heatsink provides a large heat dissipation area. The card also features fan control and fan monitoring, you are able to read fan speed & Asic temperature from CCC or software. IceQ is one of the quietest coolers. The card is below 28dB dB when watching movies, surfing Facebook, working. The card is quiet in 2D mode and remains quiet whether you are gaming, online socializing, entertaining or working.
iTurbo is your software assistant to control your graphics card to be quiet, cool and experience overclocking by simply pressing the iTurbo Button! User Friendly Overclocking Software: Cooler, Quiter, OC!
iTurbo's Fan Control and Fan Monitoring allow easy adjustment of your card to its maximum cooling performance or to run your card quietly! Press iTurbo: OC Right Away! With the smart auto overclocking function, users can experience a slight performance boost for HIS selected graphic cards with just one click! Powerful Overclocking Software: Either you wish to unleash its full potential or to make it more environmental friendly, iTurbo is ready for you!
Features:-
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £185.99 inc VAT.
ORDER NOW
MSI HD 7850 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Cards w/ Nexuiz, Sleeping Dogs & Dirt Showdown PC Games @ £167.99 inc VAT
nonl2br<Font size="4"><b>Key Features</b></font><br>
<br>
<b>Propeller Blade on Twin Frozr III</b><br>
- The special blade design generates 20% more airflow than traditional design.<br>
- 10C cooler & 13.7dB quieter than reference design!!!<br>
<br>
<b>MSI Afterburner overclocking utility</b><br>
- Supports overvoltage function<br>
- Supports advanced fan speed control.<br>
- Supports burn-in stability test. <br>
<br>
<b>All Solid Capacitors</b><br>
- 10 years ultra-long lifespan<br>
- Lower Temperature and Higher Efficiency<br>
<br>
<b>AMD Eyefinity Technology Support</b><br>
- AMD Eyefinity Technology supports maximum 6 displays with 2 DisplayPorts via Multi-Stream Transport (MST HUB).<br>
<br>
<Font size="4"><b>Specifications</b></font><br>
<b>Graphics Engine</b> ATI Radeon HD 7850 <br>
<b>Interface</b> PCI Express x16 3.0 <br>
<b>Memory Type</b> GDDR5 <br>
<b>Memory Size(MB)</b> 2048 <br>
<b>Memory Interface</b> 256 bits <br>
<b>Core Clock Speed(MHz)</b> 900 <br>
<b>Memory Clock Speed(MHz)</b> 4800 <br>
<b>DVI Output</b> 1 <br>
<b>HDMI-Output</b> 1 <br>
<b>Mini DisplayPort</b> 2 <br>
<b>HDCP Support</b> Y <br>
<b>HDMI Support</b> Y <br>
<b>Dual-link DVI</b> Y <br>
<b>Display Output (Max Resolution)</b> 2560x1600 <br>
<b>RAMDACs</b> 400 <br>
<b>DirectX Version Support</b> 11 <br>
<b>OpenGL Version Support</b> 4.2 <br>
<b>CrossFire Support</b> Y <br>
<b>Card Dimension(mm)</b> 197 x 111 x 38mm <br>
<b>Warranty</b> 3 Years<br>
Only £167.99 inc VAT.
ORDER NOW
MSI HD 7850 Power Edition Twin Frozr IV OC 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz, Sleeping Dogs & Dirt Showdown PC Games @ £175.99 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/7000PowerEdition.jpg" alt="Power Edition" /><br>
<br>
<br>
<b>Power Edition Architecture</b><br>
- Triple Overvoltage: Adjustable GPU, Memory and VDDCI via Afterburner to unleash the potential of the graphics card<br>
- Enhanced PWM Design: more phases provide higher overclocking capability and better stability at peak load<br>
<br>
<b>Twin Frozr IV cooler with Dust Removal technology</b><br>
- Provides 22°C Cooler and 11dB quieter operation than reference product<br>
- cooler removes dust build up every time it is switched on to keep cooling performance optimal<br>
<br>
<b>Military Class III Components</b><br>
- Components meet US Military Standard MIL-STD-810G to ensure the best stability and quality<br>
- Hi-C Caps, SFC and Solid caps are the most reliable and efficient components available<br>
<br>
<b>MSI Afterburner Overclocking Utility</b><br>
- MSI's exclusive overclocking software<br>
- Built-in Kombustor stability test software<br>
- Built-in real-time video capture software<br>
<br>
<b>Core Clock Speed(MHz)</b> 950 <br>
<b>Warranty</b>3 Years<br>
<b>Product Review:</b> http://tbreak.com/tech/2012/05/msi-r7850-power-edition-review/ <br>
- Supplied with Nexuiz & Dirt Showdown PC Games<br>
Only £175.99 inc VAT.
ORDER NOW
MSI HD 7870 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz, Sleeping Dogs & Dirt Showdown PC Games @ £189.98 inc VAT
nonl2br
<br>
- 15? cooler & 9dB quieter than reference design!!!<br>
<br>
<br>
<b>AMD GHz Edition</b><br>
- World's First graphics card with default 1 GHz core clock.<br>
- Provides better performance and visual experience.<br>
<br>
<br>
<b>Graphics Engine</b> ATI Radeon HD 7870 <br>
<b>Core Clock Speed(MHz)</b> 1050 <br>
<b>Card Dimension(mm)</b> 270 x 118 x 42mm <br>
Only £189.98 inc VAT.
ORDER NOW
MSI HD 7870 Hawk 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz, Sleeping Dogs & Dirt Showdown PC Games @ £215.99 inc VAT
MSI R7870 Hawk, equipped with AMD's 28nm Radeon HD 7870 GPU. MSI introduce the flagship design concept of Lightning series into R7870 Hawk, adopting UnlockedDigitalPower that incorporates an Unlocked BIOS, DigitalPWM Controller, and Enhanced Power Design to boost overclocking potential and make overclocking easier than ever. With the industry first "GPU Reactor" power panel, it reduces power supply noise as well as increases overclocking stability. As for thermal solution, MSI R7870 Hawk utilizes the latest Twin Frozr IV Thermal Design with Dust Removal Technology. The dual 8cm fan setup with PropellerBlade Technology generate massive airflow for fast heat dissipation while remaining whisper silent. The two form-in-one heatsinks improve cooling for memory and the power module as well ensure structural integrity. The R7870 Hawk uses Military Class III components which have passed rigorous testing to meet MILSTD810G standards, guaranteeing the card's stability and reliability under actual use conditions. Moreover, the "3X3 OC Kits" are designed to simplify overclocking, which makes it easier for users to fine-tune their graphics cards. Competing with flagship design of Lightning series, R7870 Hawk absolutely stands out on top among the industry's HD 7870 based graphics cards.
The MSI R7870 Hawk implements the innovative "GPU Reactor" power panel which, when installed on the back of the GPU, increases current volume by 5 times, reduces power supply noise by 20%, and improves the overall GPU overclocking stability. MSI GPU Reactor is easy to install and has built in safety features that make it easy even for ordinary users to install and remove.
MSI exclusive Unlocked DigitalPower is composed of the Unlocked BIOS, DigitalPWM Controller, and Enhanced Power Design. Unlocked BIOS gives you an increased PowerTune limit (up 57%) as well as more relaxed AMD Catalyst Control Center and OverCurrent Protection limits which means access to the MSI R7870 Hawk full overclocking potential. The DigitalPWM Controller provides more stable and accurate voltage signals than analog designs, meaning the voltage can be adjusted more quickly and precisely during overclocking. Enhanced Power Design provides more power than the reference design. Equipped with Unlocked DigitalPower, the MSI R7870 Hawk is the best tool for gamers.
The MSI R7870 Hawk incorporates the next-generation Twin Frozr IV Thermal Design. The striking design of the new Twin Frozr IV comes from the two 8cm PWM fan setup with PropellerBlade Technology and two 8mm SuperPipes to enhance heat dissipation. MSI has also incorporated its exclusive Dust Removal Technology in the Twin Frozr IV enhancing the Thermal performance over a long lifespan because at every boot, the fan will reverse for 30 seconds when booting to remove dust from heat sinks. The two form-in-one heat sinks cool the memory and power modules, ensure the structural integrity and card is protected from any accidental dents or scratches. The Twin Frozr IV on MSI's R7870 Hawk is 15? cooler and 5.7dB quieter than the reference design.
Features:-
- Core Clock: 1100MHz
- Processing Cores: 1280
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Only £215.99 inc VAT.
ORDER NOW
Sapphire HD 7850 1024MB GDDR5 PCI-Express Graphics Card w/ Nexuiz, Sleeping Dogs & Dirt Showdown PC Games @ £143.99 inc VAT
The Sapphire new model in the HD 7850 family of graphics cards based on the revolutionary new graphics GCN (Graphics Core Next) architecture from AMD. Offering excellent performance at an even keener price point, SAPPHIRE HD 7850 1GB OC GDDR5 model will ship with core clock of 900MHz and memory at 1200MHz (4.8Gb/s effective). Equipped with a dual BIOS, and the new output configuration of Dual link DVI-I, Dual link DVI-D, HDMI and Display Port.
SAPPHIRE HD 7850 1GB OC GDDR5 also features SAPPHIRE’s latest dual-extractor cooler technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load.
Features:-
- Memory: 1024MB GDDR5
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £143.99 inc VAT.
ORDER NOW
Sapphire HD 7850 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz, Sleeping Dogs & Dirt Showdown PC Games @ £161.99 inc VAT
Offering excellent performance at an even keener price, SAPPHIRE HD 7850 shares the features of the HD 7000 family with Dual-X cooling technology, a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load.
Features:-
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
Sapphire HD 7870 GHz Edition 2048MB GDDR5 PCI-Express Graphics Card w/ Nexuiz, Sleeping Dogs & Dirt Showdown PC Games @ £199.99 inc VAT
The new SAPPHIRE HD 7800 series of graphics cards is based on the third family of GPU’s from AMD built in its new 28nm process and featuring the highly acclaimed GCN graphics processing architecture.
The Sapphire HD 7870 GHz Edition is equipped with 2GB of the latest GDDR5 memory clocked at 1200MHz (4.8Gb/s effective) with the new dual-extractor technology - Dual-X - a highly efficient multi-heatpipe cooler with dual fans providing quiet and very cool operation during normal operating conditions, and superb cooling performance even under extreme load.
Features:-
- Core Clock: 1000MHz
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Only £199.99 inc VAT.
ORDER NOW
This represents awesome value for money, as such you guys have no excuse to NOT:-
GET YOUR WALLETS OUT - BUY NOW!!
that is very impressive a week old game for free taking in to consideration the value of the games for thats making the 7850 2GB sub £100 card.
EDIT was to slow
I bought that one last week, with paid for next day delivery.
It arrived yesterday with no haribo, so I'm not overly impressed with the company. That slow for next day delivery takes the biscuit.
The card however I cant fault, thus far it hasnt managed to get over fifty degrees, so I really must start pushing it a bit.
the witcher 2 looks beautiful, and I really need to start modding skyrim to get it looking as pretty as it is capable of becoming.
Ordered one of the above cards a few days ago. Any ideas when I'll receive the codes, and will it be all 3?
I got the Nexuiz and CoD codes in the box(not the actual gpu, outer box) and got the Dirt code from 5UB in the customer service forum. I'm assuming they haven't started sending out the Sleeping Dogs codes yet
EDIT: and the CoD code was only with the HIS cards.
What happened to the VTX 7800 X-Editions, out of interest? Were they an "as stocks last" kind of item?
Just found the Nexuiz one in the box, but no Dirt - even on the order form only said nexuiz + sleeping dogs.
Sorry if it's wrong place to be discussing this, just seems slightly odd I don't receive a game, yet the deal is still being promoted :/
