*** Weekend Round of Deals *** ROUND 1 - NZXT
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Throughout the day today we are doing deals - they will be offered every 30mins to an hour, so keep your eyes peeled for some bargains.
Round 1 - is NZXT Cases.
NZXT Phantom Enthusiast USB3.0 Full Tower Case - Black @ £93.98 inc VAT
NZXT presents the cutting edge Phantom Full Tower Chassis. Designed with sleek, pristine contours, the Phantom radiates personality and quality. As with all NZXT products, we strive to set apart our customers from the rest with unique, original designs – we run the extra mile so you won’t have to settle with the typical rectangular box. The Phantom delivers high performance cooling advantages with 7 fan cooling options, dual radiator support, quad watercooling cutouts, and five 20W per channel fan controls. An innovative 5.25” screwless system, vast space to encompass 7 hard drives, and five 5.25” bays enable smooth customization. Establish your power, your presence.
- High Performance Cooling Advantages
– Phantom’s extensive cooling capabilities include 7 fan cooling options with dual 200mm, single 230/200mm, triple 120mm, and front 140mm fan options.
- NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels.
- Simple Installation
– Phantom celebrates an array of innovative features designed to enhance every stage of the build
- Meticulous cable management is easily attainable with large spacing behind the motherboard.
- Innovative all-new 5.25” screwless rails make installing and swapping HDDs an effortless process
- Rubber grommets dampens vibration during operation.
- LED on/off button to control fan lighting
- Rubber PSU and case feet to reduce vibration
- Easily removable front and top panels
- Top mounted USB, Audio/Mic, and E-SATA ports
– Features support for larger heat sinks, graphics cards, and E-ATX motherboards enabling enthusiasts to include any of today’s hottest components
- Vast space within the enclosure allows for 7 hard drives with SDD support and up to five 5.25” bays
Was £104.99 Inc. VAT
Only £93.98 inc VAT.
ORDER NOW
NZXT Phantom Enthusiast USB3.0 Full Tower Case - White @ £93.98 inc VAT
- Top mounted USB, Audio/Mic, and E-SATA ports.
Was £109.99 Inc. VAT
ORDER NOW
NZXT Phantom Enthusiast USB3.0 Full Tower Case - Orange/Black @ £93.98 inc VAT
ORDER NOW
NZXT Switch 810 Big Tower Case - Black @ £132.98 inc VAT
Experience the pinnacle of chassis design! Switch 810 is an epic hybrid case built for the hardcore PC enthusiast. This full tower chassis introduces a first of its kind concept for more versatility and adaptability to any configuration. It can be modified for superior water cooling or superb airflow through seamless operation. The Switch 810 is the ultimate powerhouse suitable for any type of PC enthusiast – whether you are liquid cooling, silent performance, or extreme airflow. You will have full control to customize all the features of Switch 810 based upon your preference.
Some unique features that set Switch 810 apart is the adjustable Hybrid Fins that reduce sound up to 40-60% when closed or open passageways for maximum airflow. Keep dust out by simply shifting the Hybrid Fins closed. Switch 810 has a rear LED light for illuminating the I/O in the dark, removable HDD cages for bottom radiator installation, a stealth bay, ability to mount triple 120/140mm radiators with 90mm of space, and potential to install up to 7 HDDs. For the first time, NZXT is introducing advanced HDD cages equipped with two 140mm pivot fans for directing airflow to the VGA and CPU. Anything is achievable with this chassis. You can only explore the infinite possibilities of PC expansion with the Switch 810.
- Unique hybrid full tower chassis optimized for extreme liquid cooling, airflow, or silence
- Supports high-end water cooling solutions up to three fans for push and pull configuration: 90mm of internal top space with top 360/420mm and bottom 140/240mm radiator support for unmatched liquid cooling
- Four watercooling cutouts for easy liquid cooling management on the rear panel
- Spacious CPU cutout for mounting high-end CPU coolers without removing the motherboard
- Removable top 5.25” plates to accommodate wide radiators
- Clever hybrid fin design allows the user to choose between maximum airflow or sound reduction
- Innovative right-mounted HDDs for easy hard drive replacement
- Removable HDD pull-out cages and large storage capacity for 7 hard drives
- Equipped with two 140mm pivot fan slots for directing airflow at 15^(0) to the VGA and CPU
- Rear white light for visibility in dark environments with a toggle switch
- Dual high-speed USB 3.0, hard drive dock along with a SD card reader for transfer and quick access to multimedia
- 5.25" hard drive hot swap with SATA III support
- Nine expansion slots for installing EATX motherboards with Quad SLI or Triple Crossfire
- Supreme cooling capacity with up to ten 140/120mm fans
- Stress-free wire management and 23mm clearance in the rear allows for superb wire-tucks
- Ten large specialized cutout holes for easy cable management
- Easily removable bottom filters in the front and rear to prevent dust from entering
- Tool-less 5.25” and 3.5”/2.5” SSD hard drive installation for convenience and ease of accessibility
- Large acrylic window with a view to show off the interior of your rig
- Dimenions: (W x H x D) 235 x 595 X 585 mm
- VGA Clearance Maximum: 375mm (w/out fan), 350 (installed), 285 (full pivot)
- Front Cooling: 2 X 120/140mm (1x 140mm included)
- Rear Cooling: 1 X 120/140mm (1x 140mm included)
- Top Cooling: 3 X 120/140mm (1x 140mm included)
- Bottom Cooling: 2x 120/140mm
- Interior Cooling: 2x 120/140mm (1x 140mm included)
- Drive Bays: 4 External 5.25" Bays / 6 Internal 3.5" Bays
- Screwless Rail Design
- Expansion Slots: 9
- Motherboard Support: E-ATX, XL-ATX, ATX, MICRO-ATX, Mini-ITX
Was £149.99 Inc. VAT
Only £132.98 inc VAT.
ORDER NOW
NZXT Switch 810 Big Tower Case - White @ £132.98 inc VAT
ORDER NOW
NZXT Phantom 410 Enthusiast Midi Tower Case - Gun Metal @ £88.99 inc VAT
NZXT introduces the next descendant of the revolutionary Phantom, the Phantom 410. The beautiful and sleek Phantom design set the trend of all white chassis and idealized optimal expansion and cooling. In comparison to its predecessor, the Phantom 410 delivers more value for every dollar spent and possesses an acrylic window that allows gamers to admire the power of their rig.
The Phantom 410 features an innovative right mounted HDD rails, a solution for easy hard drive replacement. This mid tower comes equipped with a dual radiator water cooling solution with a clearance of 30mm, an interior pivot 120mm/140mm fan slot, the capability of installing up to 8 fans, and a single 30W fan control. The Phantom comes with up-to-date internal 2x USB 3.0 headers that directly connect to the motherboard. Be the envy of all PC gamers - the Phantom 410 is bringing sexy back.
- Clearance for top 240mm dual radiator for water cooling solutions
- Adjustable interior pivot 120mm/140mm fan slot for directional air flow
- Removable HDD cage to allow more room for extended video cards
- Innovative right mounted HDD rails for easy hard drive replacement
- Single 120mm/140mm side fan with acrylic window for interior viewing and cooling
- Front Internal 2x USB 3.0 headers, 2x USB 2.0, audio and microphone input
- 30W 3-step fan control for setting up your system for silence or performance
- Wire management support up to 25mm space for easy cable management
- Screw-less 5.25” and HDD trays that secures 2.5” SSD
- Cooling capability of up to eight fans (2x 120mm and 1x 140mm LED fan included)
- Dimensions(W x H x D): 215 x 516 X 532 mm
- Front Cooling: 2x120mm or 1 X 140mm (1x120mm included)
- Rear Cooling: 1 X 120mm (included)
- Side Cooling: 1 x 120mm or 1 x 140mm
- Top Cooling: 2 X 120/140mm (1 x 140mm included)
Only £88.99 inc VAT.
ORDER NOW
NZXT Phantom 410 Enthusiast Midi Tower Case - Black @ £79.99 inc VAT
NZXT introduces the descendant of the revolutionary Phantom, the Phantom 410. The beautiful and sleek Phantom design set the trend of all cases and idealized optimal expansion and cooling. In comparison to its predecessor, the Phantom 410 delivers more value for every penny spent and possesses an acrylic window that allows gamers to admire the power of their rig.
- VGA Clearance Maximum: 305mm (w/o fan), 280mm (installed), 230mm (full pivot)
- Top Cooling 2 X 120/140mm (1 x 140mm included)
- Drive Bays: 3 x external 5.25" / 6 x internal 3.5"
- Expansion Slots: 7
Was £94.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
NZXT H2 Classic Silent Midi Tower Case - White @ £74.99 inc VAT
NOISE – chaotic wavelengths that distract, distort, impede, confuse, and endanger the gamer during a life and death situation. Intelligently constructed to give you peace of mind, NZXT’s H2 Classic Series Silent Midtower Chassis minimizes extraneous hums, clicks, whirls of your system to enhance your concentration, accuracy, and deadliness.
- Touch powered fans with fan filter for easy maintenance and fan swapping
- 30W 3-step fan control for airflow settings at 40%, 70%, and 100% of maximum fan speed
- Top hot swap capable SATA HDD Dock (requires an AHCI capable motherboard and hot swappable HDD) and USB 3.0 port for the most up to date function
- 8 Front facing HDDs for optimal airflow
- Noise dampening foam and a top magnetic fan cover for minimal PC noise
- Ample 25mm space behind motherboard for cable management
- Dimensions: 215 x 466 X 520 mm
- VGA Clearance Maximum: 310 w/o HDD, 250mm with HDD
- CPU Heatsink Support: 170mm
- Front Cooling: 2 X 120mm @ 1200rpm ( included )
- Rear Cooling: 1 X 120mm @ 1200rpm (included)
- Top Cooling: 1 X 140mm
- Bottom Cooling: 1 x 120mm
- Drive Bays: 3 x external 5.25" & 8 x Internal 3.5"/2.5" Slots
- Expansions Slots: 7
- Motherboard Support: ATX, MICRO-ATX, BABY AT
Was £84.99 Inc. VAT
Only £74.99 inc VAT.
ORDER NOW
NZXT Source 210 Midi Tower Case - White @ £30.98 inc VAT
Gamers spend approximately £30 per game, buy X number of video game titles per year. You know what it’s like…it adds up very quickly. Sometimes gamers are starving college students, sometimes gamers have girlfriends; the green keeps flying away. NZXT’s Source 210 is here to provide the basic chassis to house your rig. It’s modest and contains the essentials for performance. It’s the chassis you can afford.
The Source Series is NZXT’s chassis line designed to be a starting block for first time builders or a stepping stone for those who want to upgrade their rig later on. Each chassis faithfully serves their purpose as an affordable, memorable part of your system building experience; it may just be a keeper.
- Bottom Mounted PSU – Positioned for the most effective PSU ventilation
- Wire Management Support – 20mm space for a neat and easy build
- Aluminum Textured Panel – Accents the chassis for a clean, modern look and feel
- Dual 120mm Front Intake – Takes advantage of front facing HDD bays for excellent airflow
- Maximum Cooling Potential – Eliminate heat by installing up to seven 120mm fans
- Also fits 2 x 120/140mm fan
- Dimensions: (W x H x D) 195mm x 440mm x 495.5mm
- VGA Clearance Maximum: 230mm w/ hard drive, 330mm w/o hard drive
- CPU Heatsink Support: 160mm
- Drive Bays: 3 External 5.25" DRIVE BAYS / 8 Internal 3.5" HDD Drives
- Front I/O Ports: 1 x Standard Audio/Mic, 2 x USB 2.0
Was £36.98 Inc. VAT
Only £30.98 inc VAT.
ORDER NOW
