You only need one rogue PC which is behind the curve on AV updates (and a dumb user) and it can get in.
Yes, spam email (often Hotmail) containing a link to a compromised website. The payload is delivered using javascript.
You only need one rogue PC which is behind the curve on AV updates (and a dumb user) and it can get in. Trouble is if that one PC has access to a share it will change files for malicious shortcuts. Assuming all other PCs are up-to-date, they will now start throwing virus alerts when users try to access their files. Cue lots of calls to the help desk and a repair job on the file share.
Point of entry = ?
Oracle Java SE Rhino Script Engine Remote Code Execution Vulnerability (CVE-2011-3544) Patched by Oracle in October 2011.
Oracle Java SE Remote Java Runtime Environment Code Execution Vulnerability (CVE-2012-0507): Patched by Oracle in February 2012.
Maybe if Java Patches weren't so obtrusive and disruptive, Patch Adoption wouldn't be such an issue![]()
I note Oracle have finally got off their backsides and provided a patch today though.
