*** Weekend Round of Deals *** ROUND 2 - Zowie Rodents
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Zowie mice are now on offer with Round 2.
Zowie EC1 Pro Gaming Mouse - White @ £39.98 inc VAT
The mouse use an optical encoder instead of the cheaper traditional mechanical system and added a optimized rolling system developed by ZOWIE, which ensures that the mouse wheel is the most durable and precise mouse wheel on the market today. Most optical mice are 125Hz which can be artificially raised to 500 - 1,000Hz through driver installations. The ZOWIE EC mice are the only optical mice which has 1,000 Hz from standard, without any installation of drivers. One of the primary features of the ZOWIE EC-series is the lift-off distance. ZOWIE EC-series has made it possible to create low lift-off distance.
- Dimensions: 70 x 43 x 128 mm (WxHxD)
- Colour: white glossy
- Surface: smooth
- Sensor: optical
- Resolution: 2,000 dpi
- Levels: 500 / 1,000 / 2,000 dpi
- Speed: 1.02 m / s
- Sampling: 6,500 FPS
- Acceleration: 15 G
- Lift-off distance: 1.5 mm
- Buttons: 5
- USB report rate: 1000 Hz
- Connection: USB (Gold)
- Cable length: 2 m
- Compatibility: Windows 2000 / XP / Vista / 7, Mac OS 10.2 or
Was £44.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Zowie EC1 eVo 2300 DPI Pro-Gaming Mouse @ £44.99 inc VAT
1.5 mm lift-off distance - one of the lowest on the market to date
One of the primary features of the ZOWIE EC-series is the lift-off distance. ZOWIE EC-series has made it possible to create one of the lowest lift-off distance currently available in any optical mouse on the market - 1.5 mm.
1,000Hz USB Report Rate - plug and play with 1.000Hz
Most optical mice are 125Hz which can be artificially raised to 500 – 1,000Hz through driver installations. The ZOWIE EC mice were the first optical mice to introduce 1,000 Hz from standard, without any installation of drivers.
Improved mouse wheel
The mouse use an optical encoder instead of the cheaper traditional mechanical system and added a new optimized rolling system developed by ZOWIE, which ensures that the mouse wheel is the most durable and precise mouse wheel on the market today.
DPI-adjustment
Adjusting DPI on the fly is not really an innovative feature, but ZOWIE decided to put it on the mouse anyway, as it's important for a gamer to be able to optimize the settings to create the perfect feeling when playing.
DID YOU KNOW?
That you can change the Hz of the EC-mice without any software?
- 100% stable optical mouse developed by HeatoN
- Ergonomic designed right-hand gaming mouse
- 1.5mm lift-off distance
- Improved mouse wheel system
- Easily change to 1000, 500 or 125 Hz
- Plug and play! No drivers or software
- DPI adjustment: 450/1150/2300
- Operating system: Win2000/XP/Vista/7, Mac OS X V10.2 after
- Frames Per Second: 6,400
- USB report rate: 1000/500/125 Hz
- Dimensions: 128 x 43 x 62mm
Was £49.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Zowie EC2 eVo 2300 DPI Pro-Gaming Mouse @ £44.99 inc VAT
DPI-adjustment
DID YOU KNOW?
- Dimensions: 120 x 40 x 58-65 mm
Was £49.99 Inc. VAT
ORDER NOW
Zowie EC2 Pro Gaming Mouse - White @ £37.99 inc VAT
- Dimensions: 65 x 40 x 120 mm (WxHxD)
- Layout: Left Handed
- Colour: White
- Finish: grip
- Sensor: optical
- Speed: 1.02 m / s
- Buttons: 5
- Cable length: 2 m
Was £42.98 Inc. VAT
Only £37.99 inc VAT.
ORDER NOW
Why would you go for one of these over a Razer?
I'd most definitely have one of these over ANY Razer mouse. I've got the original EC1 and it's the best mouse I've ever owned.
Difference between evo and non evo? And then EC1 and 2?
As far as I can tell the eVo has 1000mhz polling, and has a rubber coating on all of it (compared to the Black EC1) which was just on the top of the mouse; stops sweating I believe. EC1 is shaped more towards the original Microsoft Intellimouse 3.0, whereas the EC2 is more of a Razer Deathadder shape. Depends on what you find comfiest!
Both the same shape. EC2 is just smaller.
There's one problem. I ordered 4 mice from OCUK and have my current Qpad 5K aswell I think that's from OCUK also. I have tried all the mice I liked all tracked fantastically except the EC1 and EC2. Under very low sensitivity gaming these seem to skip when Razer, Logitech and Qpad mice haven't. I'm sending all the other mice back but keeping the EC1 as it feels 50X better in my hands than the others but well I'll just have to live with the problem. Have a big boogie mousemat black cloth. I thought this was a problem specific to me maybe but on youtube another guy has the same setup from me and brought the products from OCUK also and has the same issue. I decided to try my mouse on no mousepad just wood and it seems to do it on this also.
