**OcUK WILL NOW BUILD A GAMING LAPTOP (HD 7970M) TO YOUR SPECIFICATION: LAPTOP CONFIGURATOR!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OcUK is now building its own laptops again, but with a twist, you can pretty much configure everything bar the graphics and chassis. So we've gone with the most popular and best bang for buck gaming laptop which is based on a 17.3" chassis and wait for it includes a dedicated AMD HD Radeon 7970M 2GB GDDR5 graphics for sublime performance.
OcUK Extreme P170EM 17.3" LED Full HD Intel Processor, 1600MHz DDR3, SSD + HDD, ATI HD 7970M 2GB GDDR5 Graphics Card - Windows - Black
For hardcore gamers the OcUK Extreme P170EM is the perfect choice. There is no more powerful or better constructed option, with the latest Intel Core I7 Processor there is no shortage of power and for those who only demand the most powerful, we can construct the OcUK Extreme P170EM with an Intel I7 Extreme processor too. Though our own in house testing shows the best bang for buck performance comes from the Intel Core I7 3720QM & 3820QM processors, so we highly recommend these when choosing a processor option.
This chassis uses the absolute very latest in technology such as SATA3, USB3.0, Bluetooth, WiFi but the most impressive of all is the fact this system feature an ATi Radeon 7970M with 2GB of GDDR5 dedicated memory for absolutely blistering performance. Infact this is the fastest gaming laptop we sell and more importantly its also one of the best value and offers you the ability to tailor to your exact needs.
With a backlit keyboard you will no longer have problems finding the keys during the dark or whilst playing your favourite shoot 'em up! Not only that but with a choice of colours to suit your environment and taste your notebook will look more stylish than ever!
With a LED backlit 17.3" screen with True HD (1920x1080) resolution games have never looked so good on the go or ran so smooth due to the power of the ATI HD 7970M onboard graphics. The OcUK Extreme P170EM feature a blue backlit keyboard and high quality THX speakers for the ultimate gaming experience.
For memory we only use the highest performance and most reliable for laptops, which is Corsair Vengeance which is set to run at 1600MHz with T1 memory timings resulting in absolute instant response. 8GB is the default choice which is more than adequate for all task and gaming, we only recommend 16GB kit if your also doing a lot of photography work or heavy multi-tasking. Corsair Vengeance 1600MHz will extract the very best performance from the OcUK Extreme P170EM causing zero bottlenecks in the system.
For hard drive options, we recommend the primary drive as an SSD drive, this means from point of pressing power on your should be at the Windows 7 Desktop in approx 10 seconds and with an SSD applications and games load more or less instantly. Of course if you preferre capacity you can choose a large capacity HDD or a Hybrid drive too. Our recommendation is to select an SSD for the primary drive along with a HDD as the secondary drive for storage.
Specification:-
- Operating System: Choose from the drop down options!
- Display: 17.3" SuperBright LED True HD Display (1920x1080 Resolution)
- Graphics: AMD Radeon™ HD7970M 2GB GDDR5
- Storage: Choose from the drop down options!
- Optical: Choose from the drop down options!
- HD Audio
- Mic Noise Suppression
- Dolby Home Theatre®
- 4W Stereo Speakers (2W x 4)
- Subwoofer
- 2 megapixel Webcam
- Processor: Intel® Core™ i7 Processor - Choose exact model from drop down options!
- Physical Specification: 412mm x 276mm x 41.8~45.4mm (3.9kg with battery)
- Memory: 8GB DDR3 System Memory at 1600MHz (4GB x 2) OR choose 16GB DDR3 (8GB x 2)
- Main Chipset: Intel HM77
- Communication: 10 / 100 / 1000 Gigabit Ethernet LAN,Wireless LAN, Widi Support
- Bluetooth 3.0
- 1x HDMI Port
- 3x USB3.0 Ports
- 1x USB2.0 Port
- 1x E-SATA
- 1x DVI-I
- 1x DisplayPort
- 1x Microphone IN
- 1x Headphone OUT
- 1x DC IN
- 1x RJ-45 Jack
- 1x IEEE 1394a
- Kensington Lock: YES
- 8 Cell Smart Lithium-ION Battery
- Fingerprint Scanner
- 9in1 Card Reader
- 2yr Warranty (1yr Parts, 2yr Labour)
Service Package
- Full 24 Month collect and return warranty (12 month on parts)
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this Notebook for You?
Immense performance, powerful graphics and sleek hardware all combine to create the "OcUK Extreme P170EM", perfect for the gaming enthusiast.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
* No OS systems are fully tested with the same extensive methods as systems chosen with an operating system. Including tests such as CPU, memory and GFX stress tests. All no OS systems are formatted completely before shipping.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
PRICE: CONFIGURE FROM DROP DOWNS!
ORDER NOW
Have a play guys, you can configure a pretty awesome laptop and we can build these up and test them in short time so delivery is typically 48hrs. :)
5UBLIME performance you say!? Very nice! :D
Good to see a decent laptop, but not only that, one you can customise to what you want! :)
