£600 for Motherboard, Ram, CPU and Graphics card.
4 Feb 2006
I have wanted to upgrade my PC for a while now but could never justify it as my PC plays games mostly on medium-high settings anyway.
Recently on newer games I'm having to turn down settings some more which is starting to bug me as I want to start playing games all on high again.
I have a "spare" £600 to burn and I really want new componants now!
I will only need motherboard, ram, cpu and graphics card as I can salvage the rest of the things needed from my current PC.
I play games at 1920x1200 and would like to get the best possible stuff I can with this money.
I'd probably rather stick with an Nvidia graphics card and an option to go SLI later, but I am open to AMD cards too.
Many thanks!
What is your current spec, what wattage is your PSU? and do you have an SSD or anything like that?
I currently have:
CPU: Intel Q6600 2.4ghz
GPU: Nvidia GTX 285
Motherboard: Gigabyte P35C
Ram: 4gb OCZ PC 6400
PSU: Enermax Liberty 620w
I have no SSD but I might look to buy one of those in the future.
I currently have:
GPU: Nvidia GTX 285
But do you have an aftermarket cpu cooler or not? You could always get one later if you want to keep the spec i made. Or if you can up your budget £25-30, we can fit you one in.
I have an aftermarket cooler currently, I can't quite remember which one it is though. Are they the same on the newer sockets, the way it fits?
+1 would change oem cpu to retail though and get a decent cpu cooler at a later date such as the k2 which is about 50 pounds.
If my cooler doesn't fit will the stock cooler actually be too bad to use?
Many thanks!
I got it about 2 years ago, it fits my LGA775, it's just 4 pins that push in and twist and pull to remove. If it's the same for the newer sockets then I guess it's fine.
No mate, i think that is just a 775skt stock cooler. You can just use the stock cooler on the 3570k until you can afford a new cooler.
It's not the stock cooler. I'm sure it's something like an artic freezer, but I have no record of this on my order history, and I'm not sure what model it is.
I've just looked at some message history, it's an Artic Cooling Freezer 7 Pro.
I don't think it's the Rev 2 version and I can't find much information about the previous one, so I assume it's not going to be compatible.
