First watercooling setup - advice/spec check
2 Mar 2009
Hey guys, im going to take the plunge into watercooling for the first time. I currently have a h50 and want a silent system with better temps.
I've modified a Define XL so i can mount a triple 360 rad in the top, and im going to cool my 3770k and gtx 680. I've been doing my research and this is the spec ive come up with. Would just like someone to give it a check to see if everything is ok.
Aqua Computer AquaGraFX - GTX 680 Water Block £89.98
(£74.98) £89.98
(£74.98)
Alphacool Laing D5 Vario Pump 655 - NO TOP £56.99
(£47.49) £56.99
(£47.49)
XSPC EX360 Multiport Radiator £52.99
(£44.16) £52.99
(£44.16)
XSPC Acrylic Dual 5.25" Reservoir for Laing D5 £49.99
(£41.66) £49.99
(£41.66)
XSPC RayStorm CPU WaterBlock (Intel) £49.98
(£41.65) £49.98
(£41.65)
Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin £13.99
(£11.66) £41.97
(£34.98)
XSPC HighFlex Hose 1/2" ID, 3/4" OD, 19/12.7mm, 2m, White £6.98
(£5.82) £6.98
(£5.82)
XSPC G1/4" to 1/2" ID, 3/4" OD Compression Fitting (Black Chrome) £3.49
(£2.91) £27.92
(£23.28)
Sub Total : £314.02
FREE SHIPPING (DPD Next Day)
(This can be changed during checkout) Shipping : FREE
VAT is being charged at 20.00% VAT : £62.80
Total : £376.82
There are a few things missing still like coolant etc, im mainly concerned about the main components.
Looks like a nice set up.
You can also easily fit a 240 in the base of the XL at a later stage if you feel you need it (360 probably fine for what your cooling but water cooling is addictive)
(agree with Cleeecoo about the res btw)
YOUR BASKET
1 x XSPC RayStorm D5 EX360 WaterCooling Kit £242.99
1 x Aqua Computer AquaGraFX - GTX 680 Water Block £89.98
2 x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) £2.99 (£5.98)
Total : £350.34 (includes shipping : £9.50).
The res on that is slightly better as it allows for pump speed adjustment. The rad isn't a multiport though.
The kit comes with fans. As for coolant, mayhems pastel/X1 would be my choices :)
Excellent, yea im looking at the mayhems pastel white to match my case.
I was thinking about removing the bottom HDD cages and putting a rad at the bottom as well, but i think it will be overkill atm. Maybe a future upgrade if i go SLI.
