My first attempt at detailing
5 Aug 2006
Derbyshire
Hey all.
Had my first go at detailing this week. All the kit I have bought and some items i.e. Snow foam were not purchased due to the cost at this early stage.
The test car is my old one that my brother now has :p.
I did the following:
Rinsed off with pressure washer
Washed twice with two bucket method
Used tar remover
Clayed
Dual action polisher with medium and soft pads, and medium and low cutting polishes
Thin layer of wax.
Just looking for comments really :).
Before:
After:
I am having some issues with image resizing so please be patient with me :p.
Rather than trying to explain I will just link you to the item I bought :p.
http://www.cleanyourcar.co.uk/polis...ion-polisher-menzerna-intro-kit/prod_721.html
The roof and bonnet needed tackling hard. I did not use the hard pad as I do not know how thick the paint is and also I have read that Jap cars tend to have soft paint.
On hindsight I would have gone over the roof again with the softer pad and softer polish just to be completely sure I'd got all the faded paint off.
It is quite strange how some panels have faded so much more than others, yet they were all equally as red when the car was bought 7 years ago!
As I was trying to make do with the bigger pads I have given the yellow (medium) pad a good battering around the more intricate areas.
looks nice in the photos, but seeing you are from stoke you can do mine & i will tell you after :) hint hint
joking aside job well done there me thinks,,,,,
I live in Loughborough most of the time but my parents live in Uttoxeter, but nobody has heard of it so I just say Stoke on forums :p.
I am certainly looking to do another car soon. I have another lesson soon to cover alloy wheels and stone chips :).
Looks good :).
Did you mask off the seals etc before polishing? Very easy to discolour them, not that it matters as much on an older car.
The top looks great, really brought the colour back.
Looks good :).
I did but I forgot to order the proper stuff, so I used masking tape. Tbh the only bits that mattered where the chrome bits on the grill really, the black external trim I did not bother with so much.
If I did it again, I'd tape the trim up properly with the proper tape :).
Get an 'after shot' in the sun please. ;)
The car was extemely swirly and now the swirling is almost gone, but not completely gone. As this was my first time I did not want to take off lots of paint as I was testing the water with the dual action polisher.
I would take a photo in the sun but it seems to be hiding this week! I was just glad of no rain yesterday so I could finish the polishing off :p. I have a single crappy energy saving lightbulb in the garage so polishing in there means I am polishing blind as I cannot see which bits need going over again due to the poor lighting. I can't polish outside in the sun as the polish gets baked on then.
I do agree that a true comparison of before vs. after should both be done in sunlight though.
Nout wrong with masking tape :p can leave a bit of residue sometimes though. I may give the polisher a go on my 350 once it comes... although I'd be a bit apprehensive.
Uttoxeter is a nice place mostly & it is only a few mins down the a50 for me.
I work in Loughborough and live near there, car needs a clean badly, get in touch :D
In loughborough I have a flat on campus for a wardening role with no drive so all my detailing will be in Uttoxeter back home. I certainly need cars to improve my skills on but it consumes a whole weekend and the price of consumables means I can't do freebies :p. I really want snow foam and need a paint depth gauge for me to be able to have the confidence to tackle swirls harder.
Haha.
Tell me about the price of consumables... and it's so easy to get caught up and just go mad. My spend for the 350 cleaning currently comes in at around £200+.
That's snow foam, wash mitts, polishes etc and also grabbing some EXO as it's well worth the money.
So far I've spent around £220 and as I haven't got any small polish pads I've pretty much shredded one trying to do the fiddlier areas! I could easily have spend £500 but that is just too steep at this early stage. I reckon an additional £25 too in clay, polishes etc.
Shame, coulda come and done it for the day, its been too long since mine has been done and I'm thinking just get ir detailed or at least cleaned + more and interior valeted, although a detailer may see me & hurt me for the state its in!!
