Yes, that's it Mal
I noticed you edited your post - probably wise you wouldn't want to be suspended again would you?
I think the general consensus from the thread where you fried your old card was that you weren't listening to people who were trying to help (myself, Dave and Greg et al.) and it backfired.
It worries me when you're giving out overclocking advice which involves voltages that's all. I don't know the safe numbers on 7970's as I don't own one but I'm wincing every time you give advice on the matter![]()
As I only have one infraction for being mean to Dave Beast I would say that you learn some lessons from your time-out's![]()
.... that is one hell of a long time if you're addicted to gaming like i amYou don't want to get permanent banned though! You'll lose your free shipping an MM access. Not good!
i randomly opened up msi afterburner cause my gpu went quite all of a sudden, and my voltage reset itself but everything else stayed the same, whats that about?
Dunno, I chose to save the overclock profiles that I was happy with (I think you can save 5) and each time I select them they seem to work OK.
edit; had your card gone into powersave mode as that has happened with my previous card.
How do you check?
No what happened was my core clock and mem clock speed both stayed the same 1100/1575 (gpu z confirmed this) but my voltage went back to stock
when i had mine on 1.3v
on MSI it never crashed at 1.3v either, !
I can only think that you may have previously 'applied' the settings for the core and memory but when you tweaked the voltage you did not apply again?
that's a typo error sorry, because if you read my earlier posts/ my other thread, i've been saying exactly the same as you all day..... keep your hair on, mine is on 1.193v up from 1.17v
by the way, you dont know that much either.... because 1.25 might be too high on air as well..... because mine blew from 1.2 to 1.25v and it blew first thing in the morning. i mentioned 1.25 as being too high earlier on today, or at least needing a thorough testing first.
but to be really careful i would start to worry as soon as i got to about 1.2v, because i cant be sure when my last card started this sparking sound, simply because i OCd last time with the rig about 10ft away, but today was ok because i had my head right inside the pc case... i heard nothing, not even coil whine.
How come in another thread you said you never went over 1.25? Your figures don't add up Mal...
when i had mine on 1.3v i noticed no performance boost over 1.22, i only noticed artifacts on the screen...... silly me ignored this, i just thought this was typical Crysis 1...... i then backed off to 1.22v, the card ran much better/smoother.
on MSI it never crashed at 1.3v either, but i also noticed strange artifacts here as well, the video would stop start stop start as the slider went up to max load all the time, i just thought ``i dont like seeing this, what do i do.. help``..``oh ****, i'd better back right off``
QUOTE]
nope nope nope, i never said my card blew at 1.3v, the card blew after i backed it off to roughly 1.25 or 1.22, i've always said this, in addition the card blew 2 days later..because there was a one day gap before i went to the shop, it blew the next morning, it was somewhere between 1.2 to 1.25v for two days
greg where did i say the card blew at exactly 1.3v, please quote me right, i didn't, i said i was suspicious that the damage was done there.
Yeah Mal you have tripped up there, i haven't heard of people blowing their cards on 1.25 apart from you so i take that with a pinch of salt. Also before you blew it you would see warning signs well before.
