Well, after previously having a fair amount of hassle with an MSI laptop repair that took about 5 weeks to complete I'm having issues again.
The laptop came back from repair (motherboard swap in the end) and I found the power plug wasn't THE best fit for the DC socket. It worked tho so let it go.
Now, down the line it seems the poor fit has caused the socket/plug to overheat and melted the plug onto the pin in the middle of the socket.
This ended up with the pin breaking off and the power supply obviously being rendered useless as well.
It's been off to MSI for warranty repair (now covered in the UK by a company called D&J Henry, I think a MASSIVE improvement over it going to Poland like last time) and they are quoting an out of warranty repair needed etc.
Does this seem reasonable?
Some thoughts:
1) The replacement motherboard from the last swap probably didn't have a full term of warranty on it after repair (they are only quoting 3 months on the parts here if I agree to the fix) would that be fair grounds for them to stand on?
2) The power supply thing probably should have been reported so they could claim it was due to customer neglect?
Either way I'm currently being billed either: £176 for motherboard, shipping, handling or £50 to return un-repaired, neither seem that reasonable really?
Some thoughts:
