Driving test is tommorow, :/
Minors mean nothing really, I passed my test (17 years ago) with 14 minors and now have 12 years no claims bonus with one non fault claim, completely not my fault as a car did a u-turn into my path with absolutely no indication whatsoever.
I thought they put you out of your misery if you have a major, since theres not much point continuing.
If you asked half way through what you currently had, would the examiner tell you?
Well guys i failed first time... 4 minors 1 serious. :(
was right at the end of the test aswell 5 minutes from the end.. was for something that i didnt even think i would fail on.
was aproching a junction, turning left, light was green, looked over to my right to see if there was any emerging traffic, by the time i looked back to my front/left the light had changed to red.
was one of those bloody traffic lights that did not have any amber signal...... by the time i looked over i had passed the line and i hesitated on breaking and she did it for me = there for i new i had failed right away.
i was gutted to say the least cause i did everything i thought i would messup on perfectly...
ohh well i have rebooked today for oct 10th at 2:37pm
really bad time considering my time this time was at 9:17am...
....... dam stupid silly mistake can really do you in :(
Never seen these before?
If you mean the light was out then usually there are 2-3 sets of lights incase one does have a bulb out.
was she fit?
Don't worry man, all the best drivers fail their first test! :)
My first test was 3 minors, 1 major - the major was approaching a roundabout at too high a speed on a slightly damp road; because of the road conditions an oil/diesel spill wouldn't have been visible and had there been one there (there wasn't) I might have had a problem (I didn't!). Ho hum.
Passed my second test was 3 minors.
