"Backing up" Steam and Origin games...
14 Oct 2004
location, location
Folks, tomorrow I will likely be rebuilding my PC because I'm moving from HDD to SSD as the primary drive.
In order to save myself the hassle of re-downloading about 30GB worth of Origin (BF3) and Steam (various) games, is there any way to back the games up so I can effectlvely copy them to the SSD once it's installed?
Thanks in advance!
Sadly not :/
With Origin I ended up having to reinstall though I believe you can backup some of the installer files and then pause your reinstall download, close Origin, and overwrite the files that were downloading. Someone that has used Origin more may be able to advise you better on this though.
I reformatted my pc not long ago I just copied the "Battlefield 3" although I lost my single player saved file.
Regarding Origin and what FrenchTart said above, copy the folder files.
On your new machine, begin the game downloads (1 at a time preferably). Close Origin and pause the download, now copy the old files into the new game folder and overwrite etc.
Open up Origin again and continue the download, where you'll only have to download a couple of MBs.
When doing steam its just the steamapps folder, but dont forget to copy the ones in Current User/My Document/My Games, some saves are found here.
I've copied Origin games to other hard drives a few times, just copy the origin games folder over, its in program files. With bf3 i had to right click the game in my library and click repair, i also had to install punkbuster so you may have to also if one of your games is bf3.
Steam has its own game back-up feature anyway - just right click on any game, select 'backup game files', tick the games you wanna backup, choose where you want it and how big each file is (it spilts it so you can copy onto discs or whatever you want) and Steam does the rest.
Quite a lot easier to just copy the entire steam folder unless space is a big issue though.
I found the Steam feature very slow VS just copying the folder
