Ive used the injector files the DX ones an set every thing i can to ultra, your set up should do the same Tibbz.
Have you used the DX mod's, if so which are you using as ive seen 3 different ones that might be the problem.
The first set i used were very buggy so i tried this set that im using now an seem a lot more stable.
