I want to propose, need advice...
27 Sep 2005
Burbage, Hinckley
... I have no idea how to find my gf's ring size without her knowing! She doesn't have any rings I can use for reference.
Help!
I'll test her ring size for you.
Thank god. I thought I was going to have to do it.
Maybe while she's asleep use some calipers on her finger? Piece of string round the finger? If she wakes up tell her you wanted a hand shandy but were thinking it'd be cool to try out some bondage at the same time.
Ha haaaa - I was waiting for some 'ring' related humour to come back ;) thought you all could have done better though tbh!
She's Swedish so her mother lives 1400 miles away... might try the piece of string bit, although I'm not sure the excuse would wash :)
Take her to some cheap little market somewhere and when you pass the jewellry stall, jokingly try a few on her and when she walks off, give the stall owner a nudge and a wink to keep a hold of the one which fits, then come back and buy it later.
Faliing that, I have some suggestions which would get me suspended, so I'll keep them to myself :D
Buy a speculum and... Oh wait.
Find a picture of her hand next to an object you can find and measure, take into account distance from the object and scalability to the size of said object. You can get a rough guess from it.
Math solves everything.
Or measure her finger while she's asleep.
Well the usual procedure is to buy the ring and then you go back to have it changed to the correct size if you don't know it. Even if you did find some cunning way to measure it then there is no guarantee it would fit.
And lol@coals glad I wasn't the only one who had that thought first. :D
Ooh, if there's a special occasion coming up buy her a cheap ring as a present, then if it doesn't fit you can be like "oh noes, let's get one that fits!" And bang, you have your sample. If it fits first time: win.
Only really works if you're willing to wait a bit, because buying her a ring out of the blue for no reason might be a bit suspicious.
I baked a giant party ring and wrote this on it.
Had already seen a ring that I liked, so I took her to try it on after giving her the party ring :)
There was no way I was buying the ring for my wife before she saw it.
I ended up proposing using a Haribo jelly ring, but put it in a real ring box.
Yes, it was a bit sad doing it that way, but better than a lifetime of days spent peering into jewelery shops every time you go to town with 'why didnt you get that one'
Yes, Buy 2 680s for SLI and when she asks what you spent all the money on you can say it's an engagement ring. Which will technically be true because your order will certainly come with some haribo which you can propose with!
