BMW experts, can you check this vehicle out for me?
5 Series with CIC Nav are ultra-rare plus they don't do a 535i E60 so not really a good suggestion.
Other than the unfortunate lack of pro nav and Xenons thats an excellent car in the OP - the LCI E90 is a much better looking car than the pre facelift version. The wood dash is nice.
You'll be unlikely to get the CIC iDrive on that budget, which means you might as well get one of the cheaper 335i with <60,000 miles and save some money.
http://www.autotrader.co.uk/classif.../1500/keywords/335i/postcode/ha11nb?logcode=p
That one looks quite good to me. If you would prefer the newer iDrive and are flexible you could get a 5 series with one on that budget.
That does look a much better spec but I can't stand the rear of the E90 pre-facelift.
Or the front. If you can't find an LCI E90 look at an E92 instead. Anything to avoid the pre facelift. Hasn't aged well and looks frankly crappy.
Needs to have 4 doors, have also been looking at some E60 530i.
[TW]Fox;22730659 said:
Wait and buy an F10. Much much better car.
Just had a look at the F10, the inside is like WOW. The F10 does look so much better, the 335i is around 35k at the mo so might have to wait quite a long time.
