Quietest 120mm fan
20 Aug 2012
Greater London
quick question: what's the quietest 120mm fan i can buy, that moves a pretty decent amount of air around a machine? I'm not too bothered about speed, so long as there's a lot of air going in/out and it's quiet :)
Be quiet - Silent Wings 2...replaced all my stock fans with them and they are quiet...very quiet
Sorry but I have owned AF 120's (airflow) by Corsair and they are nowhere near silent without a fan controller up to 1850RPM. If you bought the silent version they would be alright. I had to cut the fan mesh out of my old case to stop the airflow version whining away at high RPM. They are also very expensive unless bought in twin packs. After reading the above post a bit more he did link the quiet edition, 1100 RPM which the 120mm I had were very quiet at, 1100 RPM was my "silent" speed for my old case.
Noctua 120mm fans, are very quiet, and also have high static pressure.
I have been told many times that the Scythe Gentle Typhoon 1150RPM moves a lot of air for how much noise it makes.
I use the Corsair AF140's and really like them, but the 120's did not amaze me at all, except for under 1200 RPM.
Ive not had a problem with mine Brian, it is the quiet edition and i have it hooked up the fan controller on my 650D. Even at full tilt its still quiet.
Thinking of getting 2 x 140mm static pressure ones for the exhaust on the top of the case or would you leave it as 1 x 200mm cooler master megaflow ?
Yeah, after reading your post, they are fine at 1100rpm and have a nice pitch to them. I had the airflow version (1850RPM).
What case do you have? I find that my 200mm bitfenix fan moves as much air through the roof of my arc midi as the stock 140mm fans did, guess 200mm just have bad static pressure though. If the 200mm is moving air I wouldn't change it, a 200mm is meant to move more air than two 140mm because it actually has more surface area or something like that. Should be quieter too.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-027-BX I put this in the top of my Arc Midi, look's really good and has so many mounting holes lol. Come's with two ways to mount it as well, has the anti vibration option as well as screws. Hand held the airflow is similar to a desk fan. The fan mesh/filter in the top of my case restricts it a bit but when I remove the top it shifts loads of air and is really quiet, wish I could fill my whole case with them.
http://www.overclockers.co.uk/showproduct.php?prodid=FG-023-BX&groupid=701&catid=2331&subcat=2335 Maybe this would fit. :D
Yeah, it's not silent, but it's not loud either, more realistic db level. More corsair fans would look better probably, match the other ones you have.
AF120s don't spin to 1850. 1100 for the Quiets & 1650 for the Performance. Only the SP120 Performance go above 1650 (upto 2350)
Link
I have the SP120 Performance on my CPU cooler and upto around 1400 RPM I don't hear them. At 1500 you can notice them but it's not really till 17-1800 that I'd call them noisy. At 2300 they're like a Turbo-prop engine lol.
Haven't tried the AF's yet but I will be soon.
Sorry yeah, 1650, thanks for correcting that. :) Still were quite loud at 1650, but quieter than cheap fans I have heard at that speed.
Wow... Looks like I've got a lot of choices then... Any way of possibly narrowing it down, or is this mostly opinion-based?
TBH there's not much in between the suggestions other than the aesthetics.
But how quiet a fan really is will always be subjective to the individual.
For instance I might think my rig is quiet but someone else might come along and think it's not if you get my meaning.
