Is it normal for your waterpump to get hot?
DDC pumps get hot under operation & you can purchase heat sinks that bolt onto the motor.
D5 pumps run very cool.
Did a little experiment to check if a pump was working correctly.
Connected a DDC pump to a simple res & run some pipe from the outlet of the pump back to the inlet of the res, approx 1 meter in length.
Run this configuration for a short period of time & the water started to get hot
The pumps do generate heat. It says this in the instructions for the EK all in one kits.
When i was leak testing my loop i ran the pump for 48hrs with no fans on the radiator and my water was about 5 degrees above ambiant temp.
Anything above 40 degrees will feeh hot to touch rather than just warm but the pump shouldnt really get to this temp. Not a modern pump anyway.
