Can of worms...
Goblets actually don't really push your hamstring flexibility, it's ankles and/or glutes.
The Tony G/Cressey point about anterior core is kind of stupid. I'm not saying that anterior core strength deficits don't limit squat form (it very often does), but is it really that holding a weight out in front of you activates anterior core enough to correct form, ORRRRRR, is it that holding a weight out in front of you allows you to counter balance a larger sit back around more vertical shins...
Both? Probably, but it depends on the individual, and he hasn't addressed ankles at all. The rest of the article is good though.
TC, please keep consulting the form thread, a lot of this is covered there.
You need to develop a core bracing pattern.
Keep an upright torso with goblets, from what you've said you clearly weren't. You want perhaps 20 degrees of hip flexion, then to drop down between your ankles by moving your knees out and over your toes.
