What 240 rads will fit in the Arc Mini?
22 May 2010
Minibotpc
I'm looking at getting a fractal Arc Mini case for my current build as i see more potential to fit more radiators in it.
I need to know though what 240 rads will fit in this case? I see in google images that it will accommodate 2 x 240 radiators... 1 at the top and 1 at the front.
Which ones will fit though in push OR pull configuration only?
i have that case and this is what the user manual says
the component support in the case when using a radiator in the top is depending on the thickness of the radiator. see info below. when having a 2x120mm radiator mounted in top, you cannot use the rear 120mm fan slot at the same time. (you could mount the fan outside the case though)
-up to 40mm radiator thickness: support for most water cpu coolers and larger memory modules
-up to 50mm radiator thickness: support for most water cpu coolers and standard memory modules with a max height of 40mm
-up up to 70mm radiator thickness: support for only certain water cpu coolers, depending on the water inlet and outlet. supports only standard memory modules with a max height of 40mm
it doesnt mention a front radiator however you could fit one if you cut away the bottom front hdd enclosure which is riveted to the case. you could fit a thicker radiator there as there wont be such a tight space.
Thanks for that, it's very interesting! I thought both hard drive caddies were removable in this case?
bottom one is riveted on so all thats needed is to drill it.
you could stick a thick 120mm fan above the bottom cage though.
also there is a bottom intake so you may be able to put another 120mm rad there. which would mean 240 + 120+ 120
im not experience with w/c but that should be enough to cool most setups
Decided to stick with my case and mod it to fit a 240mm rad up top. Check progress thread in my sig if interested.
