Started playing my Sentinel in PVP again after getting bored with my Sorc and Assassin. They definitely need nerfing, even in recruit gear I can run rings around most people, they hit really hard and have nifty cooldowns. Zen followed by spamming blade rush cuts most people down if force leap, that one that gives you 100% crit and master strike doesn't.
hallelujah, somebody agrees with me!!
What spec you using by the way and do you think Marauders are they same?
I use combat spec, which is carnage for Marauders. There's a lot of discussion of watchman/annihalation vs combat/carnage, there are for pros and cons for each IMO but I've tried both and I much prefer combat.
I fancy levelling a Jug DPS next.
After playing a number of classes I think PT's/Vanguards need a nerf and Sorcs/Sage's need a buff. Not happening in 1.4 though which is a shame (at least not in the DPS tree). It seems the devs think that they are just healers as that's where the buffs are going.![]()
Cheers, I use Carnage too. Thinking of rolling a Sent, only 18 on my mara.
I see by the new patch notes, lots of changes for Deception Assassin.
http://www.darthhater.com/articles/swtor-news/21578-patch-notes-game-update-1-4
Vanguard Nerfs:
- Sweltering Heat's snare has been reduced to 30%.
- Incendiary Round's range has been reduced to 10 meters.
- Assault Plastique's range has been reduced to 10 meters.
Sage Buffs:
- Kinetic Collapse: The Incapacitation effect caused by this skill no longer breaks on damage.
- Mental Alacrity now additionally provides immunity to interrupts for its duration. It has improved visual effects to demonstrate this effect.
- Force Speed now has a 20-second cooldown (down from 30).
What's the point in rolling the same class? If you have a mara, then level a guardian?
I have only one Republic toon. It will not take me long to get a Sent back up to Level 18.
And now the real truth....Imperial have become so **** on ToFN and I sick of losing every WZ...![]()
There are a couple of decent guilds about on the Imp side of TOFN for Level 50 PvP.
"Impulse" are pretty good and are giving us some good RWZ matches recently. "Whatever" are OK, but they get carried big time by their Sniper.
This makes me sad considering I'm leveling a Marauder on ToFN with the intent to mainly PvP![]()
Did our fastest run of EC HM 8Man tonight, 1h20min - recorded the last fight too; anyone interested to see if I run an encode and what not?
Is this still not F2P yet? I did subscribe but I only want the story so stopped paying until it goes F2P.
http://youtu.be/ShDpcfk-FjI
Fear my leet editing skills... didn't add music though
November time according to interwebs
good video mate.
I'm a clicker too
How did you get your ops bar like that?
What did you use to record that?
