MPC-BE released (video media player)
Don
21 Oct 2002
Parts Unknown
It's a mod of the MPC-HC player.
A bit more polished, and they've added Aud/Sub buttons to the main screen.
Looks great imo
http://sourceforge.net/projects/mpcbe/files/MPC-BE/
Pick either 32bit or 64bit, then download the 'installer' version.
You'll also need to update your DX9 files to use it.
Web Installer / Full installer
  • To get it looking like this, press 2, then Ctrl + 5, then Ctrl + 1.
    [*]Press 3 to revert to default view, 1 to have super compact
  • To set as default video player, press o, Formats, Modify/Video, Ok
Gonna have a play when I get home!! :)
does it upgrade my old MPC-HC or will I have to uninstall that first???
Looks like yet another re-skin of MPC.
Well, first there was MPC, then MPC-HC, which added a load of features.
Now this is fork from MPC-HC. The Sub button is a great addition!
Doesn't replace MPC-HC if you install it, it will sit in it's own folder.
Got round to trying it and it's nicer than previous MPC-HC BE mod where the UI is swisher, you can't drag the video window by dragging the video section itself any more though, you have to drag either title bar or the grey areas of the navbar UI.
I like the new media filetype icons for mkv/avi etc though!
I've copied my pch hc ini file and enabled it on the new BE then uninstalled the old HC version.
Edit*
Liking the preview on seek bar mouseover!
I can drag around using the video pane still.
How do you enable the seek hover preview?
The actual video dragging or the pane the video is in? I'm on about the video itself.
Settings > Misc for the latter.
Minor bug the drag thing though as even WMP can't be dragged from the video section itself. Oh well!
The old behaviour you could drag it by the video, I'm sure you can tweak the controls to add this feature (without it pausing).
I'll check tomorrow
If you just open MPC BE so the logo is showing you can drag then but if you play a video you can't drag using the video area.
Must be a bug :p
That MIGHT be a consequence of you using the ini from the old player. I couldnt move the player by touching the video itself on old version of mpc hc and the old be before it was abandoned. I prefer that way TBH, this version doesnt seem to have that ability. Might have to check out the ini and compare it to my hc install.
Only problem is that you can't drag the player when in window mode without pausing it and when you do disable pause/play on leftdown then it disables move.
If you click twice (not double-click, which in its default setting will toggle fullscreen mode), and hold the left button down on the second click, you can drag the window after the video has resumed playing - not a solution exactly, but perhaps a usable workaround if you need that capability.
