I bought my new MOBO and GPU at the same time, as a result i got 2 Nexuiz Games.
I still have one sitting here, have not activated the Key, don't know what to do with it.
Give it to a friend/forum user. It is better to give than receive
Give it to a friend/forum user. It is better to give than receive![]()
[Edit] then why is it the reviews i look at always use updated driver every time they have a new review. Its the first thing i look at, using old drivers sends my cursor immediately to the rex x.
Yeah, so who wants it?
I'd accept it if it's going![]()
They don't mate. Unless there's an ad-hoc review *most* reviewers use the original review of the card if that card is being used as a comparison point on a newer cards initial review.
As I said, it's a large time/money sink to re-review something when the only difference is new drivers.
Not saying it doesn't happen or anything like that - it just isn't the 'norm' due to the above mentioned point. This is why user benchmarks are decent tools when we're months into a cards life like we are now with most of AMD's/nVidia's top end cards.
I assume it is a steam activation code? I guess you could email it to me? Thanks very much for the offer
EDIT: Yeah, I'm not sure there is a PM function which is annoying.
I could Email it yes, (added you to my contacts but still no PM) so i don't know how you would give me your Email in private, you don't want to put your Email up here, it will end up getting spammed.
Perhaps a staff member would be so kind as to act as a gopher? i give the Key to him and he passes it on to you?
Be nice to us ocUK![]()
Yeah, I've just looked and it says that PM is only available for Admins, Dons and Underbosses. I suppose the best way would be is if a staff member helps as you suggested, because posting my email address here probably isn't the best idea
here... [email protected] just made that...
Will do, spending hours playing it probably isn't the best thing right before starting uni, but ahh well...![]()
You took your tests in Jun then?
Anyway, we are way off topic here, Sorry original poster![]()
You could have enabled your trust and sent it![]()
