HD 7850 1GB Crossfire questions
11 Sep 2012
I was wondering if anyone could answer a few questions because I do not really know how crossfire works precisely. I have looked at some benchmarks at various sites and it seems it is very difficult to max out the VRAM on a single 1gb version of the HD7850 on 1080p resolution, or at least it would only require some small sacrifices to get it under and such a game would probably be running on to low a frame-rate for it to even to playable on the card anyway.
However, I am wondering, does adding another 1gb version of the card in crossfire give you an effect 2gb VRAM, so theoretically crossfire-ing this card would allow you even to play Battlefield 3 on 2,560 x 1,600, 4xAA, maximum settings, or would both cards be bottlenecked as they are only 1gb?
Furthermore, especially if the latter would indeed cause problems, would crossfire on these cards at 1080p on a intensive game (say Battlefield 3 maxed) cause a the VRAM to bottleneck the card/s at all given the bump from about 40 fps to ~75 and the increase workload the cards would have.
I hope I am being clear, It makes sense in my head but maybe not on paper. I basically just do not know how VRAM works in crossfire.
1gb isn't enough now for even a single 1080p screen. Really strange that amd released a 1gb version, its a bit pointless as the 2gb version is only about £10 more.
Both cards will require a copy of the data in their own respective VRAM, so you will still only have 1GB of usable VRAM.
Ah OK thank you guys, I still wish they could do a 1.25 or 1.5 version of the card like the 570 and 580, but I think VRAM will be OK at 1080p at max settings on future games (maybe a few tweaks as time rolls on) for a long time.
As mentioned above, I wouldn't crossfire two 7850 1GB cards. The Vram would definitely cause some bottlenecks with crossfire- it might even with a single card ion some games, though I'm not sure on that one.
I saw some reviews of the 7850 1gb card and absolutely no difference at 1920x1080 on the most demanding games with a single card.
If you already have a 7850 1gb and want to crossfire I say go for it.. and let us know the results.
1gb didn't stop 560 ti SLI from being awesome.
Reviews show practically no difference in Vram stats for 1080p, people just think they need it and that 1gb isn't enough, i'd still get 2gb just in case though but so far they still hold well.
http://forums.overclockers.co.uk/showthread.php?t=18344284
If you want to add MSAA (which you would certainly have the GPU grunt to do) you would be getting more buttraped with only 1GB.
That is what I was looking for, definitely seems that the card is being restricted by its 1gb VRAM. It is a shame I cannot find the exact ram usage. I wonder if turning aero off (or using a program like gamebooster) would reign back a bit VRAM.
It would gain you up to 150Mb, but still might not be enough for BF3 and upcoming games, and certainly not enough for MSAA. Far better to find the little extra money than to have regrets a few months down the road.
I think 1080p max settings uses about 1350-1500 (factoring out the VRAM caching)
Ya, that's about what i'm using at Ultra Preset, but BF3 will use whatever is available (with in reason) 1GB is not good future proofing tho.
