Replacement DA Polisher pads : Where to buy?
4 Feb 2004
Écosse
On the high street I mean. Looked on the Halfords website but they don't seem to have much.
Also, what type should I be using to remove swirl marks?. Will be using 3M Finesse-it polish.
Ta. :)
Carters consumables online seem well priced.
You have a good polish there treat it to a good 3m pad, you need either blue or a black with that.
So, will a blue and a black from HERE do the trick?. Seems good value for money.
Im undecided. They look too cheap to be good quality and look like they would clog up a bit to easily being as they are flat.
If you have finesse it, you should follow it up with ultrafina on a blue 3m pad.
What car is it out of interest?
