Ok Folks I am looking for some more advice
I want to mount my Plasma (51”) to a Stud wall and try and drop some of the Cables down the back of the Plasterboard and pull them out at the bottom for my other A-V equipment
All the videos that I have looked at you you-tube look like they are from the USA and they all seem to show them fitting Power Sockets at the back of the TV’s
I don’t want to do that too much work does any one know of a Tutorial showing how to do it the way I would like to or close to doing it that way and I might be able to adapt it for my own use
Thanks again Lee
Thanks again Lee
That way i know exactly where they are for fixing to(horizontal line @120mm then noggins 1up 1down)easier to nail them this way
My bad yes i meant 1200mm damn this new fangled metric measuring
