I'm not the best when it comes to spec-ing programmes, but if you're not burning after 5x5/4x6/3x8/2x12 reps, you're not lifting enough weight.
And going for variations on a theme (i.e. bicep curls -> concentrators -> standing cable curls -> preachers) is not going to help you 'build' any faster.
What works best for me is a complete mix... something along the lines of:
DAY 1:
- goblet squat, reverse lunge, pullup, barbell roll-outs;
DAY 2:
- deadlift, bench press, dumbell/barbell row, plank;
DAY 3:
- step-up, chin up, side plank, shoulder press...
SUNDAY:
- Cycling.
Or variations on a theme...
However, my lifting totals are pants, so take what I say with a pinch of salt. Despite having a background in sports science (a looooooooooong time ago), I've only been lifting since consistently since the beginning of Feb this year (started in September last year, had a massive car accident in November and spent the intermittent time in rehab).
The thing you have to remember is that the weights you're using should be mean you're knackered at the end of each exercise (i.e. after 2x12 of reverse lunges). The split between days will give those muscles and nerves time to repair and adjust before getting hit again in the same pattern.
This allows them to grow and develop properly.
What you then have to match your training regime with is a decent diet and rest regime. If you don't eat enough of the right food and don't rest enough (i.e. get enough sleep each night), then you won't recover between exercise days and you will accumulate damage and tightness in your muscles as a result, and wind up giving up because you hurt too much.
There are a lot of people on this forum who have lifted longer than I have, lift more than I can, etc., and will give better advice regarding a routine than I can. At the end of the day, the fundamentals will be consistent:
- Eat enough and of the right food;
- Rest enough;
- Train like a mother******, to use FreeFaller's vernacular.
The pattern for the training is - to a certain degree - dependent on what you want to achieve (i.e. big muscles? Or big lifts? Or cutting fat%?), so will vary according to your requirements.
To answer your question, however, the linked videos are the correct exercises.
