Watercooling Tj08?
25 Apr 2010
Ipswich
Im thinking of changing to a Tj08 As my prodigy is doing my head in.
I was thinking of putting a 180mm Rad in the front and a 120 in the back and mounting a res in the bays and a pump somewhere.
Anyone here got any ideas?
Ha ha... I was just looking at the same thing!!
Needs to have enough space for SLI and CPU cooling for me though. Not sure if it does.
Could possibly fit a 180, 120 and possibly another 120 at the top where the optical bays are. (rad flat against the roof with customer hole made).
There's a guy planning on cooling SLI cards and CPU with those rads...
Will the rads cope with that amount of components??
PS07 might be a better choice as there's no 180mm fan at the front.
Although you would defo need to get rid of the drive bays if fitting a 240 in it I think.
This is exactly the type of case I'm after as long as it can cool 2x GPUs and a CPU.
Apparently you can.
I think that's a phobya rad. Curious as to what the temps would be like with the above setup!
EDIT - there's a 140 rad up there
Yeah.... defo.
Trying to see if a 230 fan will fit in the front with the phobya.
Size wise the fan looks like it will fit in the case ok. Just don't know about the mounts or where the rad will sit when mounted on it.
