Im a massive fan of Rome Total War if nvidia screw up RTW2 they will feel the sharp point of my Gladius.
The GTX 690s are nice cards when you look at them they look like something Mercedes styled rather than nvidia.
2x 7950s for under £500?
One of my original reasons for wanting an over kill system is Rome 2 just so I can see it in all its glory and of course Arma 3 , shogun 2
I want to run these beasts at ultra..if at all possible.
2 7950s will be able to max all those games, @2560 res as well. Lower framerates are more than playable on those types of games.
As for VRAM, 2GB is more than enough, as a side note...the 7950s are 3GB.
so do the 7970s 3072GB of Vram, what differentiates these cards exactualy spec wise ? no one seems to want to tell me.
4 less Compute units, that's pretty much it lol...clock for clock, the 7970 is <5% faster. The 7950s do clock well, but like anything it's the luck of the draw whether yours will clock better than average.
If you wanted to save a few extra £££ then going for 7950/670s would make the most sense as they perform very close to there older brothers and cost significantly less.
The 7970s meant to be better on power consumption I heard somewhere.
If so then paying the bit extra would be an investment if the difference in power consumption is significant.
But if it is or not I do not know.
You heard wrong, they draw more power and produce not a great deal more grunt. You would be better off paying a premium for an 80+ Platinum power supply than worrying about the few watts you'd save from 7950 > 7970.The 7970s meant to be better on power consumption I heard somewhere.
the 690 and 2 680s is to expensive for me.
unless I modify my budget somehow or save a bit longer.
You quoted 2x 7970s @ £800
The 690 is £780 on this week only
http://www.overclockers.co.uk/showproduct.php?prodid=GX-277-AS
I cannot buy this week, unfortunately.
Ignoring the AMD vs NVidia arguments, I would always choose two single GPU cards (be they 7970 or GTX680) over dual GPU cards. My reasoning is based upon the fact that dual GPU cards by their nature (double GPU's, double VRAM) are twice as likely to develop a fault as their counterparts. Single GPU cards also tend to overclock better and run cooler, given adequate space between PCI-E lanes. On top of this you get redundancy should one card fail, and more rear port options. Resale values/percentages may also be stronger.
