Ergh, and I only just updated to 12.8 because I realised I was actually crashing due to the 12.3 drivers and not CPU overclock.
How stable are these?
+1
Noticing significant gains on battlefield 3 (multi player)
Something must be wrong on your end i fear. Have you increased the power limit to +20%?
I have not tested single card or crossfire yet, but Trifire is been improved massively, how it should have been out of the box, but Zero core still does NOT work and IMO never will.
Tried to test this, but as it is BF3 is telling me I need to install Origin to play, I launched the game via Origin so go figure...
Restart browser and origin normally fixes that.
I wish it was that simple
So far tried:
Uninstall/Re-install Origin, to both latest stable and beta.
Different browser
Reinstall plugin
Restart everything (Origin/browser/OS)
Repair everything (Game & Origin)
Checked registry settings
And some other bits and bobs, I give up for now, I shouldn't have to spend 2 hours of my time to get two clients from the same publisher to recognise each other
I refuse to speak to EA's support team either, the most they will tell me is to reinstall absolutely everything and if that doesn't work then it will most blatantly be my set-up that is wrong rather than their buggy as hell client![]()
Have you installed origin on the same hard drive as windows is installed?
Nope, its now randomly working however
Edit: will fire up fraps and see what FPS I get on a bench run, 7970 stock clocks 1070/1400
Is anyone else seeing slight artifacts on BF3 when using these drivers?
I had a similar problem which i solved by adding origin back to my windows drive. You can change the game folder to another hard drive afterwards if needs be.
Mhm, that's exactly where I get them - usually on vehicles, especially destroyed ones.I thought I did actually, when I went near a tank I could have sworn a big triangle artefact drifted across the screen, only saw it once though.
Increased my minimum fps by up to 5-10fps. I expect these drivers will go official before long because of the improvements.
Found this driver online on another forum, so credit to the original uploader. (asder00)
http://www.mediafire.com/?83f9f5qjc4l8zdv
Don't forget to install the 12.8 CAP2 after the driver installation is completed.
http://www2.ati.com/drivers/hotfix/catalyst_application_profiles/amd_catalyst_12.8_cap2.exe
