- 1 Jan 2012
- Scottish Borders - UK
As above - or know of any build logs??
I haven't seen many tbh, though if radiator space is of concern it looks like it should take a pretty thick 240 + 120.
Looking for SLI options I take it?
It would indeed, a standard ATX size case too large I'm guessing? As something like the CM690 would be near ideal for a 3 component loop with 480mm or radiator space.
Tj08 is better.
Get a Dual bay res in there a D5 a 200 mm in the front a 120 in the rear and a small 3.5 Inch fan controler in the expansion slot in the front of the case behind the radiator = perfection.
On the surface the Fractal R4 appears that it would take 2 x 240 rads without any mods, not a bad looking case either, quite a small case as far as ATX cases go too.
No way. . . . there is no space what so ever in the R3 or R4 to fit 2x 240 rad's
The space between the top of the Mobo and the top two 120mm fan grills is really small.
you could get a low profile rad in there with some low profile fans but its not worth it because you'd be very tight for plumbing options.
Rip the HDD caddies out the front and mount a 240mm in the front and a 120mm in the back.
Build log here - http://forums.overclockers.co.uk/showthread.php?t=18438103
