That's not an issue if he uses Heinz extreme cooling paste:
Is this really worth the extra money? I am currently using no thermal paste to help it heat up as much as possible.
tbh i wouldnt bother with this as the reggae reggae version cools much better...
Tried snow cooling it?
Did it to my camera and it worked surprisingly nice. Just leave it outside in the middle of winter for a few months...
Its surprisingly simple. You literally go out in the middle of winter, put it in the snow and forget about it. The CPU should reach a very good overclock but be wary about the fans filling up.
You could add a urine cooling trough to keep your 8ghz overclock cool and stable whilst also acting as a handy t Rex repellant. You could also train your cats to use it so that you don't have to have a separate litter tray. A warning comes with this super duper cooling system though. Unofficial reports suggest a direct correlation with the consumption of air freshener
This... This is not going to happen... Also I don't have any cats... xD
You should get at least one cat: http://forums.overclockers.co.uk/showthread.php?t=18049556
Notice how the first one is pre-warming that monster full tower server case![]()
That is a nice case D: I think I saw some caselabs cases out the back of the local electronics store once... Do you think they would let me take one? D:
Go at night just to be sure![]()
and i'm sure they made a mistake, but I didnt hesitate, and I not have a room full of caselabs and mountain-mods size chassis'!
