Hey guys
Need to call in a handyman to redo my door threshold a bit. Basically need to shift the black rubber toward inside by half an inch, so it goes completely under the bottom of the door.
The second thing is I want to install some sealing between the door and door frame to stop the draft. My neighbour used some paint brush type of filler that is effective and durable. I'm afraid the simple/cheap sponge strips wouldn't last long.
How much do you reckon that each would cost?
Any ideas on where I can buy the materials myself? Couldn't find any on B&Q....
All suggestions are welcome.
