- 8 Dec 2002
- North Yorkshire
I've used this recipe for years , the key is the heat , the oil should literally be smoking and pour the mixture quick as possible and then put back in the oven.
I'm told the brand of flour makes a big difference to how much they rise, certainly my mum experiment a lot and found certain flour brands were useless and some really good.
Maybe chipperhead cans ay what flour he used.
Is ok, hopefully be moving to my own place pretty soon so I'll be able to buy my own ovenNew oven it is then!![]()
Dunno, not tried them.Expensive yorkshires...
Does it cook the frozen batter ones OK?
How do you make them sink in the middle like proper ones?
Like if you wanted an oversized one filled with roast beef and gravy...
Failed, though they did taste nice. Not what the rice vinegar added to them though!
My current oven, as you can see, is not one for even cooking.
I take it your not opening the door while there cooking are you? I haven't seen anyone mention it.
