im assuming 2xaa is a setting on the card, i have never had a gaming pc. ive always had consoles. i have a new machine sititng here less a gpu.
i was looking at a 7950, accually i kinda have my heart set on one but for a change i though i would accually try and save some money instead of blowing it on something lol.
glad we got that cleared up. cheers matt.
what GPU are you using to play BF3
haha.
agh dont know what to get.
the 7850 wont give me enough.the 7950 is a tad expensive and the 7970 it far to expensive.
7870 and clock the nuts off it.
If you want the full ultra experience you need a 7970/680.
However if you can make do with no aa a 7850 will suffice.
If you want 2xaa you want a 7950/670.
My 6950 can run it on 4xAA Ultra around 30fps multiplayer with no overclock so I can't see why a highly clocked 7870 wouldn't be playable.
My settings are slightly toned down and i only use2xaa on my lightning, i need those frames!!
@LtMatt have you answered my question yet on your site?(nickolpst)
My overclocked 7950 (1100/1575 stock volts) can do BF3 Ultra & 4xAA @1080p and have dips to 40-45fps but runs smooth anyway with average 55-60fps with vsync.. thats playable to me and most ppl will say the same.
I find this curious as people on here are always banging on that a 7950 is a star buy in comparison to a 670... but a stock 670 will hold nigh on 60FPS, certainly not dips to 40-45... and that's before some of the more extreme 670 overclocks I've seen
BF3 on ultra is a basic requirement for me and this comment makes me think twice about recommending a 7950
people always keep saying a 7850 = GTX 580 yet experiences here also seem to say a 7850 can't hold decent frames which a 580 can... odd odd
