Running it on ultra with x4 msaa, 1920x1200, 16xaf, HBAO on and blur turned off, single albeit highly clocked gtx 670wf. The lowest ive seen fps hit is the mid 50's on a 64 player map, particularly several of the b2k maps, (oman + karkand). I play with v-sync enabled as im only on a 120Hz lcd, with v-sync off it will hold a steady 75fps but the tearing is a bit distracting.
Not much a big difference between high and ultra. Playing at ultra the FPS drop at random is not good. So I play at high and keep a solid 60fps.
