Similar layout and completely different kit in your fractal build. I was really impressed with the Fractal Midi for its price.
Looks good.
If you're looking at the XSPC RX rads - those rads are 65mm plus the depth of the fans. They'd make that SR1 you have in the front look like a supermodel
Much better quality tbh.. I have accounted for the depth in my cutting and it should just fit in the top.
In the front i am not using fans as it has the 2 x 140mm fan blowing through from the front panel so i got buckets of room.. Hell i was thinking of getting 2 x 120.2 thermochill rads one straight after the other I dont know how it would work tho as i have never seen it done before.
also,can you please post a pic of the internal...with the reservoir as the focus so that i c how much space is between the 5 inch bay and the motherboard.
I was going to say 5 litres is a massive amount when I had a loop of 480, 240,120 rads 2 gpu blocks mobo cpu and a big duel bay res I only used 2 and half
