Today my second one of these arrived:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-052-HS
After installing it I checked CCC to see if everything was fine, which it seemed to be. Both cards register and look normal. I also put the clock speeds back to default on the first card to be safe (so they are both at stock speeds). I have 12.8 drivers installed.
I tried out The Witcher 2 to see just how much of an improvement the new card would be. Less than a minute in, my system hung for a few seconds. But all seemed fine thereafter. 15 minutes later, however, the game froze, shortly followed by a black screen requiring a manual reset.
After this I decided to use Unigine's Heaven Bench for testing as it's faster to load. Sometimes it would freeze and others it would freeze and then change to a black screen - both cases requiring a manual reset.
If I disable crossfire in CCC I have no problems at all.
The rest of my spec:
i5 2500k @4.5
4GB 1600Mhz
Asus P8P67
Antec TruePower 750W
Any help is appreciated.
Thanks,
Fledge
i5 2500k @4.5
4GB 1600Mhz
Asus P8P67
Thanks,
Fledge
