cheap as chips, spec me up
4 Apr 2004
Pontypridd
looking for a budget build for a friend. Will basically be used for office apps and internet use. Budget is up to £300, but would prefer to spend less. Only looking for base unit and theres no need for an OS.
should do him
can get an I3 processor for 40 quid more. but if its just for office apps and internet use. below processor will do fine.
or if you dont trust the 500 watt PSU in the case below let me know and ill spec again with dif case and psu. however i used one of these in my old build and it ran for a year and a half and is still working like a dream. I built my GF's mam a work computer on cheap and got her one of these cases + PSU and hers hasn't faulted either.
he probably wont need 8 GB of ram however 4GB was £22 this 8GB set was £27 might as well double up for a fiver.
YOUR BASKET
1 x ASRock H77 Pro4-M Intel H77 (Socket 1155) DDR3 Micro ATX Motherboard £67.99
1 x Toshiba (7K1000.D) 1TB SATA 6GB/s 32MB Cache - OEM (DT01ACA100) £59.99
1 x Intel Pentium G840 2.80GHz (Sandybridge) Socket LGA1155 Processor - Retail £56.99
1 x OcUK Imp MicroATX Tower Case (500w PSU) £29.99
1 x GeIL Black Dragon 8GB (2x4GB) DDR3 PC3-10666C9 1333MHz Dual Channel Kit (GD38GB1333C9DC) £27.59
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £13.99
Total : £268.54 (includes shipping : £10.00).
You forgot memory sticks mate. using the gigabyte board above in idlemans build seems like a win to me!
